- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Key Management Service
- Cloud Secret Management Service
- Key Pair Service
- Dedicated HSM
- Tag Management
- Auditing Logs
- Sharing
- Permission Control
Best Practices
- General
API Reference
- Before You Start
- Calling APIs
- API Overview
APIs
Key Management APIs
- Key Lifecycle Management
- DEK Management
- Small-Size Data Encryption and Decryption
- Signature and Verification
- Key Tag Management
- Key API Version Query
- Querying Key API Versions
- Key Import Management
- Querying Keys
- Key Grant Management
- Key Rotation Management
- Dedicated Keystore Management
- Signature Verification
- Key Pair Management APIs
- Secret Management APIs
Key Management APIs
- Historical APIs
- Application Examples
- Appendix
- SDK Reference
KMS Related
- What Is Key Management Service?
- What Is a Customer Master Key?
- What Is a Default Key?
- What Are the Differences Between a Custom Key and a Default Key?
- What Is a Data Encryption Key?
- Why Cannot I Delete a CMK Immediately?
- Which Cloud Services Can Use KMS for Encryption?
- How Do Huawei Cloud Services Use KMS to Encrypt Data?
- What Are the Benefits of Envelope Encryption?
- Is There a Limit on the Number of Custom Keys That I Can Create on KMS?
- Can I Export a CMK from KMS?
- Can I Decrypt My Data if I Permanently Delete My Custom Key?
- How Do I Use the Online Tool to Encrypt or Decrypt Small Volumes of Data?
- Can I Update CMKs Created by KMS-Generated Key Materials?
- When Should I Use a CMK Created with Imported Key Materials?
- What Should I Do When I Accidentally Delete Key Materials?
- How Are Default Keys Generated?
- What Should I Do If I Do Not Have the Permissions to Perform Operations on KMS?
- Why Can't I Wrap Asymmetric Keys by Using -id-aes256-wrap-pad in OpenSSL?
- Key Algorithms Supported by KMS
- What Should I Do If KMS Failed to Be Requested and Error Code 401 Is Displayed?
- What Is the Relationship Between the Ciphertext and Plaintext Returned by the encrypt-data API?
- How Does KMS Protect My Keys?
- How Do I Use an Asymmetric Key to Verify the Signature Result of a Public Key Pair?
- Does an Imported Key Support Rotation?
- Does KMS Support Offline Data Encryption and Decryption?
- How Do I Convert an Original EC Private Key into a Private Key in PKCS8 Format?
- CSMS Related
KPS Related
- How Do I Create a Key Pair?
- What Are a Private Key Pair and an Account Key Pair?
- How Do I Handle an Import Failure of a Key Pair Created Using PuTTYgen?
- What Should I Do When I Fail to Import a Key Pair Using Internet Explorer 9?
- How Do I Log In to a Linux ECS with a Private Key?
- How Do I Use a Private Key to Obtain the Password to Log In to a Windows ECS?
- How Do I Handle the Failure in Binding a Key Pair?
- How Do I Handle the Failure in Replacing a Key Pair?
- How Do I Handle the Failure in Resetting a Key Pair?
- How Do I Handle the Failure in Unbinding a Key Pair?
- Do I Need to Restart Servers After Replacing Its Key Pair?
- How Do I Enable the Password Login Mode for an ECS?
- How Do I Handle the Failure in Logging In to ECS After Unbinding the Key Pair?
- What Should I Do If My Private Key Is Lost?
- How Do I Convert the Format of a Private Key File?
- Can I Change the Key Pair of a Server?
- Can a Key Pair Be Shared by Multiple Users?
- How Do I Obtain the Public or Private Key File of a Key Pair?
- What Can I Do If an Error Is Reported When an Account Key Is Created or Upgraded for the First Time?
- Will the Account Key Pair Quota Be Occupied After a Private Key Pair Is Upgraded to an Account Key Pair?
- Why Is the Private Key Pair Invisible After It Is Upgraded to an Account Key Pair When Logging in as a Federated User?
Dedicated HSM Related
- What Is Dedicated HSM?
- How Does Dedicated HSM Ensure the Security for Key Generation?
- Do Equipment Room Personnel Has the Super Administrator Role to Steal Information by Using a Privileged UKey?
- What HSMs Are Used for Dedicated HSM?
- What APIs Does Dedicated HSM Support?
- How Do I Enable Public Access to a Dedicated HSM Instance?
- Pricing
General
- What Functions Does DEW Provide?
- What Cryptography Algorithms Does DEW Use?
- In Which Regions Are DEW Services Available?
- What Is a Quota?
- What Is the Resource Allocation Mechanism of DEW?
- What Are Regions and AZs?
- Can DEW Be Shared Across Accounts?
- How Do I Access the Functions of DEW?
- Why Do DEW Pemissions Fail to Take Effect Immediately?
KMS Related
- Videos
More Documents
- User Guide (ME-Abu Dhabi Region)
- User Guide (Paris and Amsterdam Regions)
User Guide
- Auditing Logs
KMS Related
- How Do Cloud Services Use KMS to Encrypt Data?
- What Types of Keys Can I Import?
- Credential Related
KMS Related
- Change History
- Before You Start
- Calling APIs
- API Overview
APIs
- Creating a CMK
- Enabling a CMK
- Disabling a CMK
- Scheduling the Deletion of a CMK
- Canceling the Scheduled Deletion of a CMK
- Querying the List of CMKs
- Querying the Information About a CMK
- Creating a Random Number
- Creating a DEK
- Creating a Plaintext-Free DEK
- Encrypting a DEK
- Decrypting a DEK
- Querying the Number of Instances
- Querying the Quota of a User
- Changing the Alias of a CMK
- Changing the Description of a CMK
- Encrypting Data
- Decrypting Data
- Obtaining CMK Import Parameters
- Importing CMK Material
- Deleting CMK Material
- Querying CMK Instances
- Querying CMK Tags
- Querying Project Tags
- Adding or Deleting CMK Tags in Batches
- Adding a CMK Tag
- Deleting a CMK Tag
- Appendix
- Change History
API Reference (Paris and Amsterdam Regions)
- Before You Start
- Calling APIs
- API Overview
APIs
- Creating a CMK
- Enabling a CMK
- Disabling a CMK
- Creating a DEK
- Encrypting a DEK
- Decrypting a DEK
- Creating a Grant
- Revoking a Grant
- Retiring a Grant
- Querying Grants on a CMK
- Querying Grants That Can Be Retired
- Encrypting Data
- Decrypting Data
- Enabling Rotation for a CMK
- Changing the Rotation Interval for a CMK
- Disabling Rotation for a CMK
- Querying the Rotation Status of a CMK
- Appendix
- Change History
- Before You Start
- Calling APIs
- API Overview
APIs
- Creating a CMK
- Enabling a CMK
- Disabling a CMK
- Creating a DEK
- Encrypting a DEK
- Decrypting a DEK
- Creating a Grant
- Revoking a Grant
- Retiring a Grant
- Encrypting Data
- Decrypting Data
- Appendix
- Change History
On this page
Help Center/
Data Encryption Workshop/
User Guide/
Sharing/
Activating a Dedicated HSM Instance Using a Shared VPC
After a Dedicated HSM instance is created, you need to activate it before using it. To do so, you need to bind it to a VPC. You can apply for a VPC or use a shared VPC.
Creating Shared VPC Resources
- Click
in the upper left corner, choose Management & Governance > Resource Access Manager.
- In the navigation pane on the left, choose Shared by Me > Resource Shares.
- Click Create Resource Share in the upper right corner.
Figure 1 Specifying shared resources
- Set resource type to vpc:subnet, choose the corresponding region, and select the VPC to be shared. Click Next: Associate Permissions.
- Associate a RAM managed permission with each resource type on the displayed page. Then, click Next: Specify Principals in the lower right corner.
- Specify the target principals and click Next: Confirm in the lower right corner.
- Check the configurations and click Submit in the lower right corner.
Using Shared VPC Resources
- Click
in the upper left corner of the management console and select a region or project.
- In the navigation on the left, choose
> Security & Compliance > Data Encryption Workshop.
- In the navigation pane on the left, choose Dedicated HSM > Instances.
- Locate the target Dedicated HSM, click Activate in the Operation column.
- In the VPC drop-down list, choose a shared VPC instance, configure the parameters, and click Activate.
Figure 2 Selecting a shared VPC
Parent topic: Sharing
