Updated on 2026-05-27 GMT+08:00
Viewing Key Details
This section describes how to view the custom key information on the KMS console, including key name, ID, status, and creation time. The status of a key can be Enabled, Disabled, Scheduled deletion, or Pending import.
  1. Log in to the DEW console.
  2. Click in the upper left corner and select a region or project.
  1. Check the key list. Table 1 describes the parameters.
    Click the search bar and select the criteria for filtering keys. Search for a key by specifying attributes.
    Figure 1 Custom keys
    Figure 2 Default keys
    Table 1 Key list parameters
    Name/ID
    Name of a key and the random ID of a key generated during its creation.
    Use this ID as the value of Path if you are creating a custom policy in IAM and have selected Specify resource path for KeyId.
    Status
    Status of a CMK, which can be one of the following:
    • Enabled
      The CMK is enabled.
    • Disabled
      The CMK is disabled.
    • Pending deletion
      The CMK is scheduled for deletion.
    • Pending import
      If your CMK does not have materials, its status is Pending import.
    Created
    Creation time of the CMK
    Key Algorithm and Usage
    Key algorithm selected during key creation and its usage
    Origin
    Source of key material, which can be one of the following:
    • External
      The key is imported to the KMS from an external system.
    • Key Management Service
      The key is a default key or created in KMS.
    Enterprise Project
    Enterprise project the CMK is used for
  2. You can click the key name to view its details, as shown in Figure 3.
    Figure 3 Key details
Related Operations
  • Obtaining an alias: Click the name of a key and click the Alias tab.
  • Changing the key name: Hover your cursor over the key name and click next to the name. Alternatively, click a key name to go to the Basic Information tab page. Click next to Name.
  • Changing the key description: Click a key name to go to the Basic Information tab page. Click next to Description.
    • A default key, whose alias suffix is /default, does not allow name or description changes.
    • A key in the Pending deletion state does not allow name or description changes.
  • Obtain key information via an API. For details, see Querying Key Information.
