Updated on 2026-07-16 GMT+08:00
Creating a Custom Key
KMS provides secure storage and full lifecycle management of keys. This section describes how to create custom keys on the KMS console, including symmetric keys and asymmetric keys. This section also describes the following operations:
When you create a key as an IAM user, you have granted the KMS CMKFullAccess or higher permissions to the IAM user. For details, see Using IAM to Grant Access to DEW.
  • You can create up to 100 custom keys, excluding default keys. Replica keys take up the custom key quota in the region.
  • Symmetric keys are created using the AES key. The AES-256 key can be used to encrypt and decrypt a small amount of data or data keys. The HMAC key is used to verify data integrity.
  • Asymmetric keys are created using RSA or ECC algorithms. RSA keys can be used for encryption, decryption, digital signature, and signature verification. ECC keys can be used only for digital signature and signature verification.
  • Aliases of default keys end with /default. When choosing aliases for your custom keys, do not use aliases ending with /default.
  • KMS keys can be called through APIs for 20,000 times free of charge per month.
For details about how to create a key using an API, see Creating a Key. Perform the following operations to create a custom key on the KMS console:
  1. Log in to the DEW console.
  2. Click in the upper left corner and select a region or project.
  3. Click Create Key in the upper right corner.
  4. Configure the parameters as follows:
    Figure 1 Creating a key
    Table 1 Key parameter configurations
    Name
    Name of the key you are creating. The following requirements must be met:
    • You can enter digits, letters, underscores (_), hyphens (-), colons (:), and slashes (/).
    • You can enter up to 255 characters.
    Key Algorithm
    Select a key algorithm. For details about the key algorithms supported by KMS, see Table 2.
    Usage
    Key usage. The value cannot be changed after the key is created. The value can be SIGN_VERIFY, ENCRYPT_DECRYPT, or GENERATE_VERIFY_MAC.
    • For AES_256 symmetric keys, the default value is ENCRYPT_DECRYPT.
    • For HMAC symmetric keys, the default value is GENERATE_VERIFY_MAC.
    • For RSA asymmetric keys, select ENCRYPT_DECRYPT or SIGN_VERIFY. The default value is SIGN_VERIFY.
    • For ECC asymmetric keys, the default value is SIGN_VERIFY. You can also select KEY_AGREEMENT.
    Enterprise Project
    This parameter is provided for enterprise users.
    If you are an enterprise user and have created an enterprise project, select the required enterprise project from the drop-down list. The default project is default.
    If there are no Enterprise Management options displayed, you do not need to configure it.
    Key Material Source
    • Key management
    • External
    Advanced settings
    A maximum of 20 tags can be added for one custom key.
    • Description
      Description of the key.
    • Tag
      You can add tags to a secret as you need. For details about operations on tags, see Tag Management.
  5. Click OK. You can view the created keys in the key list. By default, a key with KMS-generated key materials is in the Enabled state, and a key with imported key materials is in the Pending import state.
Related Operations
You also can perform the following operations.
Enabling a Custom Key
This section describes how to enable one or more custom keys on the KMS console. Only enabled custom keys can be used to encrypt or decrypt data. A new custom key is in the Enabled state by default.
  1. In the navigation pane on the left, choose Key Management Service.
  2. Locate the target key in the list and click Enable in the Operation column.
  3. In the displayed dialog box, click OK.
    To enable multiple keys at a time, select them and click Enable in the upper left corner of the list.
Disabling a Custom Key
This section describes how to disable a certain custom key to protect data. After a custom key is disabled, you cannot use it to encrypt or decrypt any data.
  • Default keys cannot be disabled.
  • A disabled key is still billable. Only deleted keys are not charged.
  2. Locate the target key in the list and click Disable in the Operation column.
  3. In the displayed dialog box, select I understand the impact of disabling keys, and click OK.
    To disable multiple keys at a time, select them and click Disable in the upper left corner of the list.
Scheduling the Deletion of a Key
You cannot directly delete a key on KMS. Instead, you can set a scheduled deletion date for the key, which ranges from 7 to 1,096 days.
Only custom keys in the Enabled, Disabled, or Pending import state can be deleted. Default keys cannot be deleted.
  • The system will delete the key once the deletion period expires. The content encrypted using the key and the generated data key cannot be decrypted. Before deleting a key, ensure that it is no longer in use. Otherwise, your service will be unavailable. You can check the key usage in either of the following ways:
  • To delete a master key with replica key created, delete the replica key first.
To schedule the deletion of multiple keys at a time, select them and click Delete in the upper left corner of the list. The following describes how to delete a single key.
  2. Locate the target key in the list and click Delete in the Operation column.
  3. On the displayed page, configure Waiting Period.
    Figure 2 Setting scheduled deletion
  4. Enter DELETE in the confirmation dialog box if deletion verification is disabled and click OK.
    If you have enabled deletion verification, select a verification mode, click Get Code, enter the code, and click OK.
  5. If a key is used to encrypt DDS, RDS, or NoSQL, after you click OK, a message "Key XXX is being used by XXX. Are you sure you want to delete it?" is displayed, as shown in Figure 3. Click Yes to delete the key.
    Figure 3 Confirming the deletion
Canceling the Scheduled Deletion of a Key
This section describes how to use the KMS console to cancel the scheduled deletion of one or more custom keys prior to deletion execution. After the cancellation, the key is in Disabled status.
To cancel the deletion of multiple keys at a time, select them and click Cancel Deletion in the upper left corner of the list. The following describes how to cancel the scheduled deletion of a key.
  1. Locate the target key in the list and click Cancel Deletion in the Operation column.
  2. In the displayed dialog box, click OK.
    After the cancelation, the key's status becomes Disabled. To enable the key, follow the instructions provided in Enabling a Custom Key.
