Updated on 2026-04-28 GMT+08:00
Enabling Key Rotation
KMS allows you to periodically rotate keys to enhance security for keys and service data. This section describes how keys are rotated in KMS and how to configure key rotation.
By default, automatic key rotation is disabled for a custom key. Every time you enable key rotation, KMS automatically rotates custom keys based on the rotation period you set. Once key rotation is enabled, certain fees will be charged. For details, see How Is Rotation Charged for a CMK?
  • A disabled custom key is never rotated, even if rotation is enabled for it.
    KMS resumes rotation when this custom key is enabled. If you enable this custom key after one rotation period has passed, KMS will rotate it within 24 hours.
  • Only CMKs can be rotated.
  • Only symmetric keys can be rotated.
  • Key rotation is supported only for enabled keys with KMS-generated key materials.
  • Enabling key rotation for a custom key may incur additional fees. For details, see Billing Description.
For an enabled custom symmetric key created on KMS, enable key rotation as follows:
  1. Log in to the DEW console.
  2. Click in the upper left corner and select a region or project.
  1. Click the custom key name to access its details page.
  2. Click the Rotation Policy tab. The rotation switch is displayed.
  3. Click to enable key rotation.
  4. Configure the rotation period and click OK, as shown in Figure 3. For more information, see Table 2.
    Figure 3 Enabling key rotation
    Table 2 Key rotation parameters
    Key rotation
    Rotation switch. The default status is .
    : disabled
    : enabled
    After rotation is enabled, the key will be rotated based on your set period.
    Rotation Period (day)
    Rotation period (day). The value is an integer ranging from 30 to 365. The default value is 365.
    Configure the period based on how often a custom key is used. If it is frequently used, configure a short period. Otherwise, set a long one.
  5. Check rotation details, as shown in the following figure.
    Figure 4 Key rotation details
    You can click to change the rotation period. After the period is changed, KMS rotates the key by the new period.
Disabling Key Rotation for a Custom Key
External keys can only be manually rotated.
  3. Click to disable key rotation.
  4. In the displayed confirmation dialog box, click OK.
