Help Center/ Data Encryption Workshop/ User Guide/ KMS/ Managing Keys/ Creating a Grant for a Custom Key
Updated on 2026-08-24 GMT+08:00
You can create grants for other IAM users or accounts to use the custom key. You can create a maximum of 100 grants on a custom key. Key permissions can be managed through two methods: custom key grants or IAM policies. Choose a method based on required scope and flexibility: Individual key grants are ideal for fine-grained control, restricting the authorization scope to specific custom keys with tailored permissions. Conversely, IAM policies are designed for unified management across multiple keys or an entire project. While IAM allows you to assign global permissions to users or user groups, it does not offer the granular flexibility of individual key grants.
  • You have obtained the ID or principal URN of the IAM user or account to be authorized.
    • User ID: To obtain the user ID, hover the cursor over the username in the upper right corner, and choose My Credentials. On the displayed API Credentials page, obtain the IAM user ID.
    • Account ID: To obtain the account ID, hover the cursor over the username in the upper right corner, and choose My Credentials. On the displayed API Credentials page, obtain the account ID.
    • Principal URN: To obtain the principal URN, go to the IAM console. In the User column, click the username to access its basic information page, and view the URN.
  • The custom key is in the Enabled state.
  • The owner of a custom key can create a grant for the custom key on the KMS console or by calling APIs. The IAM users or accounts who have the grant creation permission assigned by the owner of the custom key can create grants for the custom key only by calling APIs.
  • A maximum of 100 grants can be created for a custom key.
  1. Log in to the DEW console.
  2. Click in the upper left corner and select a region or project.
  3. Click the name of the target custom key to go to its details page and create a grant on it.
  4. Click the Grants tab.
  5. Click Create Grant. The Create Grant dialog box is displayed.
  6. In the displayed dialog box, set the parameters by referring to Table 1.
    A grantee can perform the authorized operations only by calling the necessary APIs. For details, see Data Encryption Workshop API Reference.
    Table 1 Parameters for creating a grant
    Example Value
    User or Account
    Whether a user or an account is granted.
    • User
      After the grant is created, the IAM user can use the specified keys.
    • Account
      After the grant is created, all IAM users under the account can use the specified keys.
    • Principal URN authorization
      • IAM user URN: To obtain the principal URN, go to the IAM console. In the User column, click the username to access its basic information page, and view the URN.
      • IAM agency: To obtain the principal URN, go to the IAM console. In the User column, click the username to access its basic information page, and view the URN.
      • IAM federated users and agency sessions utilize temporary credentials. Simply obtain the temporary credentials and enter them.
    d9a6b2bdaedd4ba586cabe6372d1b312
    Name
    You can name the grant.
    • You can enter digits, letters, underscores (_), hyphens (-), colons (:), and slashes (/).
    test
    Granted Operations
    The allowed grants are shown below.
    • You can create multiple grants on a custom key to provide different permissions to the same user. The user's permissions on the custom key are the combination of all the grants.
    • This parameter cannot be left blank.
    • Selecting only Create Grant is not allowed.
    • Create Data Key Without Plaintext
    • Create Data Key
    • Encrypt Data Key
    • Decrypt Data Key
    • Query Key Details
    • Create Grant
    • Retire Grant
      • A grantee can retire a grant if the grantee does not need that permission.
      • If, before retiring a grant, the grantee has granted the permission to another user, that user's permission will not be affected by the grant retirement.
    • Encrypt Data
    • Decrypt Data
    • Generate HMAC
    • Verify HMAC
    You can select multiple grants. The following grants can be created for all keys:
    • Query Key Details
    • Create Grant
    • Retire Grant
    For details about how to authorize a key algorithm, see Table 2.
    Table 2 Granting operations
    Key Algorithm
    Key Type
    Usage
    Granted Operations
    • AES_256
    Symmetric key
    ENCRYPT_DECRYPT
    • Create Data Key
    • Encrypt Data Key
    • Decrypt Data Key
    • Encrypt Data
    • Decrypt Data
    • Create Data Key Pair
    • Query Key Details
    • Create Grant
    • Retire Grant
    • RSA_2048
    • RSA_3072
    • RSA_4096
    • EC_P256
    • EC_P384
    • ED25519
    Asymmetric key
    SIGN_VERIFY
    • Query Key Details
    • Query Public Key Information
    • Create Grant
    • Retire Grant
    • Signature
    • Signature Verification
    • EC_P256
    • EC_P384
    • SECP256K1
    Asymmetric key
    KEY_AGREEMENT
    • Query Key Details
    • Create Grant
    • Retire Grant
    • Derive Shared Key
    • RSA_2048
    • RSA_3072
    • RSA_4096
    Asymmetric key
    ENCRYPT_DECRYPT
    • Query Key Details
    • Create Grant
    • Retire Grant
    • Encrypt Data
    • Decrypt Data
    • HMAC_256
    • HMAC_384
    • HMAC_512
    Digest key
    GENERATE_VERIFY_MAC
    • Generate HMAC
    • Verify HMAC
  7. Click OK. When message Grant created successfully is displayed in the upper right corner, the grant has been created.
    In the list of grants, you can view the grant name, grant type, grantee ID, granted operation, and creation time of the grant.
Querying a Grant
You can view the details about a custom key grant on the KMS console, such as the grant ID, grantee user ID, granted operation, and creation time.
  1. Click the target custom key alias to access its details page.
  2. Click the Grants tab to view the grants created for the custom key. Table 3 describes the parameters.
    Table 3 Parameters
    Grant Name
    Name of the grant when created
    Grantee ID
    ID of the authorized user or account.
    Granted To
    Whether permissions are granted to a user or account.
    Operations
    Authorized operations (such as Create Data Key) on the custom key
    Creation Time
    Time when the grant is created
  3. Click the target grant. The grant details are displayed on the right, as shown in Figure 1.
    Figure 1 Viewing grant details
Revoking a Grant
You can revoke a grant on the KMS console in either of the following scenarios:
  • A grantee does not need the custom key grant. (The grantee can either tell the user who has created the grant to revoke the grant or call the necessary API to revoke the grant directly.)
  • You do not want the grantee to have the grant.
When a grant is revoked, the grantee does not have the corresponding permission anymore. However, if the grantee has created the same grant to another user, permission of that user will not be affected.
  2. In the Grants tab, locate the target grant and click Revoke Grant in the Operation column.
  3. Enter DELETE in the confirmation dialog box and click OK if verification is not enabled.
    If you have enabled deletion verification, select a verification mode, click Get Code, enter the code, and click OK.
Editing a Grant
After you create a grant for an account or IAM user, you can edit the grant to change their operation permissions.
  2. In the Grants tab, locate the target grant, click Edit in the Operation column, and select the granted operations to be edited, as shown in Figure 2.
    Figure 2 Editing a grant
  3. Click OK.
Related Operations
