Overview
A key pair, including a public key and a private key, is usually used in asymmetric encryption scenarios, also called public key encryption. A public key can be publicly allocated to any user to encrypt data or verify signatures, while a private key must be kept securely and available only for the owner to decrypt data or generate signatures. In a key pair, the public key encrypts data so that only the corresponding private key holder can decrypt it. It is also used to verify digital signatures to ensure data has not been tampered with. The private key decrypts ciphertext and generates digital signatures to prove data integrity and reliability. Together, these keys are critical for secure communication, identity authentication, and data protection. In DEW, key pairs help to safeguard user data during storage, transmission, and processing.
Working Principles
- Encryption and decryption
- When you use a public key to encrypt data, only the corresponding private key can be used to decrypt the data. For example, user A hopes to send messages to user B securely. In this case, A can use B's public key to encrypt the messages, and B can use its private key to decrypt the messages.
- If you use a private key to encrypt data, the public key can be used to decrypt data. This method is mainly used for digital signature to verify the information source and integrity.
- Digital signature
- A uses its private key to generate a signature for data, and then sends the data and signature to B.
- B uses A's public key to verify the signature. If the verification is successful, the data is not tampered with and is from A.
Cryptographic Algorithms Supported by KPS
- The SSH key pairs created on the management console support the following cryptographic algorithms:
- SSH-ED25519
- ECDSA-SHA2-NISTP256
- ECDSA-SHA2-NISTP384
- ECDSA-SHA2-NISTP521
- SSH_RSA: The length can be 2,048, 3,072, or 4,096 bits.
- The SSH keys imported to the KPS console support the following cryptographic algorithms:
- SSH-DSS (not recommended)
- SSH-ED25519
Usage Process
| Operation | Description |
| Describes how to create and delete a key pair. | |
| Describes how to bind a key pair to an ECS, use a private key to log in to Linux ECS, and use a private key to obtain the password for logging in to Windows ECS. | |
| Describes how to: |
