On this page
Deleting a Key
Updated on 2025-01-23 GMT+08:00
Before deleting the key, confirm that it is not in use and will not be used. You can check the key usage in either of the following ways:
  • The key to be deleted is in Enabled, Disabled, or Pending import status.
  • A key will not be deleted until its scheduled deletion period expires. You can set the period to a value within the range 7 to 1096 days.
    Before the specified deletion date, you can cancel the deletion if you want to use the CMK. Once the scheduled deletion has taken effect, the CMK will be deleted permanently and you will not be able to decrypt data encrypted by the CMK. Exercise caution when performing this operation.
  • For details about the billing information about a CMK scheduled to be deleted, see Will a CMK Be Charged After It Is Scheduled to Delete?
  • Default keys created by KMS cannot be scheduled for deletion.
  • Before deleting a multi-region CMK, delete all replica keys.
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation on the left, choose > Security & Compliance > Data Encryption Workshop.
  4. In the row containing the target CMK, click Delete in the Operation column.
  5. On the key deletion dialog box, enter the deletion delay time.
    Figure 1 Entering the period after which you want the deletion to take effect
    • A key will not be deleted until its scheduled deletion period expires. You can set the period to a value within the range 7 to 1096 days. Before the specified deletion date, you can cancel the deletion if you want to use the CMK.
  6. Enter DELETE in the confirmation dialog box if deletion verification is disabled and click OK.
    If you have enabled deletion verification, select a verification mode, click Get Code, enter the code, and click OK.
    To disable operation protection, go to the Security Settings page, click Disable next to Operation Protection in the Critical Operations tab, or click Disable Operation Protection on the deletion page.
  7. If a key is used to encrypt DDS, RDS, or NoSQL, after you click OK, a message "Key XXX is being used by XXX. Are you sure you want to delete it?" is displayed, as shown in Figure 2. Click Yes.
    Figure 2 Confirming the deletion
To schedule the deletion of multiple CMKs at a time, select them and click Delete in the upper left corner of the list.
