Help Center/ Data Encryption Workshop/ User Guide/ Tags and Quotas/ Tag Management/ Searching for a Custom Key by Tag
Updated on 2026-05-27 GMT+08:00
This section describes how to search for a custom key by tag in a project on the KMS console.
Tags have been added.
- At most 20 tags can be added for one search. If multiple tags are added, custom keys that meet all search criteria will be displayed.
- If you want to delete an added tag from the search criteria, click
next to the tag.
- Log in to the DEW console.
- Click
in the upper left corner and select a region or project.
- Click the search box and enter the tag key and tag value of the resource you want to search for. The custom keys that meet the search criteria are displayed.
next to the tag.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
