Updated on 2026-05-27 GMT+08:00
Adding a Tag to a Custom Key
Tags are used to identify keys. You can add tags to custom keys so that you can classify custom keys, trace them, and collect their usage status according to the tags.
Tags cannot be added to default keys.
  1. Log in to the DEW console.
  2. Click in the upper left corner and select a region or project.
  3. Click the custom key name to access its details page.
  4. Click Tags to go to the tag management tab.
  5. Click Add Tag, as shown in Figure 1. In the Add Tag dialog box, enter the tag key and tag value. Table 1 describes the parameters.
    Figure 1 Adding a tag
    • If you want to use the same tag to identify multiple cloud resources, you can create predefined tags in the TMS. In this way, the same tag can be selected for all services. For more information about predefined tags, see the Tag Management Service User Guide.
    • If you want to delete a tag from the tag list when adding multiple tags, locate the target tag and click Delete on the right.
    Table 1 Tag parameters
    Value
    Example Value
    Tag key
    Name of a tag.
    The same tag (including tag key and tag value) can be used for different custom keys. However, under the same custom key, one tag key can have only one tag value.
    A maximum of 20 tags can be added for one custom key.
    • Mandatory.
    • The tag key must be unique for the same custom key.
    • 128 characters limit.
    • The value cannot start or end with a space.
    • Cannot start with _sys_.
    • The following character types are allowed:
      • Chinese
      • English
      • Numbers
      • Space
      • Special characters: _.:/=+-@
    cost
    Tag value
    Value of the tag
    • This parameter can be empty.
    • 255 characters limit.
      • Chinese
      • English
      • Numbers
      • Space
    100
  6. Click OK.
Modifying a Tag Value
This section describes how to modify tag values on the KMS console.
  1. Click the target custom key alias to access its details page.
  2. Click the Tags tab.
  3. Locate the target tag in the list and click Edit in the Operation column.
  4. In the displayed Edit Tag dialog box, enter a tag value, and click OK.
Deleting a Tag
This section describes how to delete tags on the KMS console.
  3. Locate the target tag in the list and click Delete in the Operation column.
  4. In the displayed Delete Tag dialog box, click Yes.
Related Operations
