Managing Binary SCA Jobs
You have completed operations described in Adding a Binary SCA Job.
Managing Scan Jobs
- Log in to the CodeArts Governance console.
- In the navigation pane on the left, choose Software Composition Analysis (SCA) > Binary SCA.
- On the Binary SCA page, check the job list. Table 1 describes the parameters.
Table 1 Parameters Parameter
Job
Name of a binary SCA job
User-defined description
Job Status
- In progress: The scan job is running.
- Waiting: An object has been imported and is waiting for scanning.
- Completed: The job is finished.
- Stopped: The job is stopped after you click Stop in the Operation column.
- Failed: The scan job is failed.
Vulnerability Severity
Detected vulnerabilities, which are sorted by risk severity
Started
Time when the job started
Duration
Time used until a job completes, fails, or stops
Operation
You can click the View Report, Stop, or Delete button here
The following introduces relevant operations on the job list.
- Filtering jobs: Select a job status from the
drop-down list to filter jobs by status. - Searching jobs: Enter a keyword in the search box (
) to find jobs by name, status, or description. - Refreshing the list: Click
to refresh the job list. - Comparing reports:
- Select two Completed jobs.
- Click Compare Reports. On the displayed page, check the results.
- Stopping a job: Click Stop in the Operation column of a Waiting or In progress job. Then, click OK in the displayed dialog box.
- Deleting a job: Click Delete in the Operation column of a job.
