- What's New
- Getting Started
User Guide
Detailed Instructions on Using Teleport
- Process
- Logging In to DES Console
- Creating a Bucket
- Creating a Teleport-based DES Order
- Receiving Teleport and Connecting Cables
- Copying Data
- Downloading and Importing the Signature File
- Powering Off and Packing Teleport
- Sending Back the Teleport
- Starting Data Transmission
- Viewing Data Transmission Results
- Detailed Instructions on Using Disks
- Managing DES Orders
About the Service
- What Is DES?
- What Are the Advantages of DES Over the Internet in Data Transmission?
- What Are the Scenarios to Which DES Is Applicable?
- In What Conditions Is DES Recommended?
- Is the Data Volume Limited for DES?
- Where Is Data Uploaded by DES Stored?
- What Information Is Contained in the DES Transmission Report?
- What Are the Requirements for Disks by Disk-based DES?
- What Is Teleport?
- In What Conditions Is Teleport Recommended?
- What Are the Advantages of Teleport-based Transmission?
- What Is the Storage Capacity of a Teleport?
- What Is the Difference Between the Source Data Parameter and teleportshare?
- Can DES Provide Data Export Service?
- How Long Does It Take to Ship a Teleport?
- How Long Does It Take for My Data to Migrate to Huawei Cloud After I Have Created a DES Order?
Operations
- How Do I Subscribe to DES?
- Why Do I Need to Create OBS Destination Buckets When Using DES?
- Can I Post Several Disks with One Service Order?
- Can I Cancel a Submitted DES Order?
- How Do I Use a Teleport?
- In What Conditions Will I Be Notified by SMS Text Messages?
- How Can I Start Uploading Data After My Disk or Teleport Has Been Mounted?
- Does the Data Directory Structure Change After Data Is Uploaded to OBS Using DES?
- What Can I Do if the Device Is Damaged During DES Delivery?
- For Disk-based DES, How Do I Send a Disk?
- In Which Statuses Can a Service Order Be Modified?
Service Order Status
- How Can I Obtain the Status of a DES Service Order?
- What Are the Possible Statuses of a Disk-based Service Order?
- What Are the Possible Statuses of a Teleport-based Service Order?
- What Does Disk to be sent Mean?
- What Does Expired Mean?
- What Does Service order canceled Mean?
- What Does Access key (AK/SK) to be entered Mean?
- What Does Data transmitting Mean?
- What Does Disk to be sent back Mean?
- What Does Transmission failed Mean?
- What Does Order under review Mean?
- What Does Preparing device Mean?
- What Does Sending to user Mean?
- What Does Sending to Huawei Mean?
- What Does Staff signed Mean?
Security
- How Does DES Prevent Data from Being Stolen?
- How Does DES Ensure Data Security?
- What Is the Anti-Misoperation Mechanism of DES?
- What Is the Function of a Signature File?
- How Can I Obtain a Signature File?
- What Is the Content of a Signature File?
- Do I Need to Post the Signature File Along with the Disk or Teleport?
- Can Background Management Personnel Obtain My Data?
- How Does Teleport Ensure Data Security?
- How Does HUAWEI CLOUD Handle the Storage Media Used for Migration After Data Is Uploaded to HUAWEI CLOUD?
- Service Tariff
About the Service
- Glossary
On this page
Show all
Help Center/
Data Express Service/
User Guide/
Detailed Instructions on Using Teleport/
After the Teleport is powered off and packed, contact the nearby logistics provider to send the Teleport back to the selected Huawei Cloud DC. Log in to DES Console and view the order details to obtain the DC address, contact person, and phone number.
- If the Teleport is damaged during its mail-back, you are liable for the compensation.
- If the Teleport is damaged by Huawei after it is received, Huawei is responsible for the fees generated during the second transmission. In addition, Huawei must ensure that your data is intactly transmitted to OBS.
- Cross-border transportation is not supported. A Teleport cannot be transferred to an address other than the country or region selected when the service order is created.
Parent topic: Detailed Instructions on Using Teleport
