Updated on 2026-09-11 GMT+08:00
Installing/Uninstalling Docker
Add this action to install or uninstall the Docker environment on a host.
Configuring Deployment Actions
  1. Create an application by referring to Creating an Application.
  2. On the Deployment Actions page, add this deployment action based on the service scenario.
  3. Configure the action using the parameters described in the table below.
    Table 1 Parameters
    Action Name
    Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./()
    Environment
    Deployment object. Select an environment whose resource type is host cluster.
    Operation
    Select Install Docker or Uninstall Docker.
    The Docker service supports only users with the sudo permission. This installation will overwrite the previous Docker version.
    Docker Version
    Target version of Docker to be installed.
    Action Control
    Whether to enable the settings.
    • Keep running on failure: Continue the task even if this action fails.
    • Execute this action with the sudo permission: Use the sudo permission to deploy this action.
Helpful Links
If you encounter any problems during deployment, see Installing/Uninstalling Docker.
