Running PowerShell Commands
This action aims to run the PowerShell command entered in the text box on the Windows host.
Configuring Deployment Actions
- Create an application by referring to Creating an Application.
- On the Deployment Actions page, add this deployment action based on the service scenario.
- Configure the action using the parameters described in the table below.
Table 1 Parameters Parameter
Action Name
Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./()
Environment
Deployment object. Select an environment whose resource type is host cluster.
PowerShell Commands
The command to be executed.
If the PowerShell command to be executed contains more than 10,240 characters, you are advised to use the extension for running PowerShell scripts.
Action Control
Whether to enable the settings.
- Keep running on failure: Continue the task even if this action fails.
Helpful Links
If you encounter any problem during deployment, see Running PowerShell Commands.
