Updated on 2025-12-15 GMT+08:00
Installing IIS
This action aims to install Internet Information Services (IIS) on environments. The following table describes the configuration parameters.
Table 1 Parameters
Action Name
Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./()
Environment
Deployment object. Select an environment whose resource type is host cluster.
Action Control
You can configure whether to enable the setting.
Keep running on failure: Continue the job even if this action fails.
Installing IIS service does not support Windows 7 and Windows 10.
If you encounter any problems during deployment, see Installing IIS.
