Running PowerShell Scripts
This action aims to run the PowerShell scripts in a specified path on a Windows host. The following table describes the configuration parameters.
Parameter |
Description |
Action Name |
Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./() |
Environment |
Deployment object. Select an environment whose resource type is host cluster. |
Running Mode |
Default and Background are available.
Script Path |
Path of the script on the target host. |
Running Parameters |
Before executing the script, set parameters. During script execution, the entered parameter values are loaded and used. |
Action Control |
You can configure whether to enable the setting.
How Do I Use PowerShell Script Execution Parameters?
- Use param($a,$b) at the beginning of the script to declare variables a and b.
- Use variables $a and $b in the script.
- When running the script, enter the values of variables a and b in the script running parameters and separate them with spaces.
Example:
The following figure shows the content of the hello.ps1 script. Set an environment variable to import a temporary value.
Figure 1 Script content
Configure parameters.
Figure 2 Settings
- Check the result.
Figure 3 Result
