Running Shell Scripts
This action aims to run shell scripts on a host in a specified environment. The following table describes the configuration parameters.
Parameter |
Description |
Action Name |
Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./() |
Environment |
Deployment object. Select an environment whose resource type is host cluster. |
Running Mode |
Default and Background are available.
Shell Script Path |
Path of the shell script on the target host. |
Running Parameters |
Before executing the script, set parameters. During script execution, the entered parameter values are loaded and used. |
Action Control |
You can configure whether to enable the settings.
How Do I Use Script Execution Parameters?
- Use $1, $2, and similar formats in the shell script to reference parameter. For example, the content of the hello.sh script is shown in the following figure.
Figure 1 Script content
- Separate running parameters with spaces, as shown in the following figure.
Figure 2 Entering running parameters
- Check the result.
In the script, $1 is replaced with test2, and the test2 directory is created.
Figure 3 Checking the result
