Updated on 2025-08-13 GMT+08:00
Stopping a Service
This action aims to stop a service with a specified port. The following table describes the configuration parameters.
Table 1 Parameters
Action Name
Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./()
Environment
Deployment object. Select an environment whose resource type is host cluster.
Service Port Number
Port of the service to stop.
Action Control
You can configure whether to enable the settings.
  • Keep running on failure: Continue the task even if this action fails.
  • Execute this action with the sudo permission: Use the sudo permission to deploy this action.
If you encounter any problems during deployment, see Stopping a Service.
