- What's New
- Function Overview
- Getting Started
User Guide
- CodeArts Deploy Overview
- Purchasing and Authorizing CodeArts Deploy
- Accessing CodeArts Deploy Homepage
- Configuring the Host Cluster of CodeArts Deploy
Creating and Deploying an Application with a Blank Template
- Creating an Application with a Blank Template
Configuring Deployment Actions for an CodeArts Deploy Application
- Configuring Deployment Actions for Software Installation
Configuring Deployment Actions for Containers
- Deploying on Kubernetes
- Deploying an Application in Kubernetes (CCE Cluster) Using Manifest
- Deploying an Application in Kubernetes (CCE Cluster) Quickly
- Deploying an Application with a Custom Kubernetes Cluster
- Kubernetes Nginx-Ingress Grayscale Deployment (CCE Cluster)
- Deploying with Helm3
- Deploying an Application on ServiceStage 2.0
- Rolling Back ServiceStage Components
- Configure Deployment Actions for Starting or Stopping a Service
- Configuring Deployment Actions for File Operations
- Configuring Deployment Actions for Running Commands
- Configuring Other Deployment Actions
- Editing the Deployment Actions of the CodeArts Deploy Application
- Configuring Parameters of an Application
- Configuring an Environment
- Configuring Permissions for Different Roles
- Deploying an Application and Viewing the Result
- Configuring System Notifications
Creating and Deploying an Application Using a Preset Template
- Introduction to CodeArts Deploy Templates
- Creating and Deploying an Application Using ServiceStage
- Creating and Deploying an Application Using a Kubernetes Template
- Creating and Deploying an Application Using the Function Deployment Template
- Creating and Deploying an Application Using the Tomcat Template
- Creating and Deploying an Application Using the Spring Boot Deployment Template
- Creating and Deploying an Application Using the Docker Deployment Template (Linux)
- Creating and Deploying an Application Using the Django Template
- Creating and Deploying an Application Using the Node.js Template
- Creating and Deploying a Common Application by Running the Shell Script
- Creating and Deploying an Application Using the Go Application Deployment Template
- Creating and Deploying an Application Using the Vue Deployment Template
- Creating and Deploying an Application Using the Custom Template
- Querying Audit Logs (Optional)
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
Managing Host Clusters
- Creating a Host Cluster
- Querying a Host Cluster List
- Deleting a Host Cluster
- Modifying a Host Cluster
- Creating a Host Cluster (Recommended)
- Querying a Host Cluster List (Recommended)
- Querying a Host Cluster (Recommended)
- Editing a Host Cluster
- Deleting a Host Cluster (Recommended)
- Querying Information About the Environment Associated with a Host Cluster
- Querying the Basic Environment Information List of an Application
Managing Hosts
- Creating a Host
- Querying a Host List
- Querying Host Details
- Modifying a Host
- Deleting a Host
- Creating a Host (Recommended)
- Querying a Host List (Recommended)
- Querying Host Details (Recommended)
- Editing Host Information in a Host Cluster
- Deleting a Host from a Host Cluster
- Cloning Hosts to the Target Host Cluster in Batches
- Deleting Hosts from a Host Cluster in Batches
Managing Applications
- Obtaining an Application List
- Creating an Application Using a Template
- Obtaining the Details of an Application
- Deleting an Application
- Querying the Historical Deployment Records of a Specified Application in a Project by the Start Time and End Time
- Obtaining an Application List (Recommended)
- Creating an Application (Recommended)
- Updating an Application
- Obtaining Application Details (Recommended)
- Deleting an Application (Recommended)
- Querying the Execution Parameters of a Deployment Record
- Cloning an Application
- Deleting Applications from a Project in Batches
- Checking Whether an Application with the Same Name Exists in a Project
- Disabling and Enabling an Application
- Managing Application Groups
- Managing Application Permissions
- Measuring Deployment Record
Managing Environments
- Creating an Environment for an Application
- Querying an Environment List of an Application
- Editing an Environment in an Application
- Deleting an Environment from an Application
- Querying Environment Details
- Importing a Host to an Environment
- Deleting a Host from an Environment
- Querying a Host List in an Environment
- Managing Host Cluster Permissions
- Managing Environment Permissions
- Application Examples
- Appendixes
Hosts
- What Are the Troubleshooting Methods for Host and Proxy Connectivity Verification Failures
- What Should I Do If Application Deployment Fails with "tomcat | Download War in url path" Displayed in Logs?
- Why Does a Task Fail on an Ubuntu Host After Being Successfully Run on a CentOS Host?
- What Should I Do If the No Host or Environment Whose Connectivity Has Been Verified?
- What Are Possible Causes of a Host verification failure?
- What Should I Do If a Draft Application Cannot Be Deployed?
- What Are Error Messages Displayed During Application Deployment?
- How Do I Find the Cause of an Application Deployment Error in Logs?
- What Should I Do If Error 403 Displayed During Application Deployment That Requires CCE Resources, Indicating Insufficient Permission?
- How Do I Roll Back a Deployed Version?
- What Should I Do If an Application Deployment Times Out?
- Does CodeArts Deploy Provide Batch and Incremental Deployment Policies?
- Do I Need to Upload a Software Package to CodeArts Artifact Before Deployment?
- Can I Deploy Web Pages Written in HTML or JS?
- How Do I Upload an Image for Container Deployment?
- Can I Use a Host to Deploy Multiple Projects?
- Do I Need to Install a Running Environment (Tomcat, Python, etc.) on the Target Host Before Deploying an Application?
- What Should I Do If Application Deployment Fails, with the Message "AnsibleUndefinedVariable: 'xxxx' is undefined" Displayed?
- What Should I Do If Application Deployment Succeeds But the Application Verification URL Cannot Be Accessed?
- What Should I Do If Application Deployment Fails Due to a DNS Resolution Error?
- What Should I Do If JDK Has Been Installed and Environment Variables Have Been Configured, But Application Deployment Fails with the Error Message "please configure JDK environment variables" Displayed?
- What Should I Do If the Log Indicates Insufficient Permissions?
- What Should I Do If the Path Is Invalid?
- What Should I Do If the System Displays a Message Indicating That No Hosts Are Found in the Environment?
- What Should I Do If an Error Is Reported When the Sudo Permission Is Used?
- What Should I Do If the File or File Path Does Not Exist?
- What Should I Do If I Have Insufficient Permissions?
- What Should I Do If the File Path Does Not Exist?
- What Should I Do If the Action "Create and Start Container" Fails on Ubuntu 22 OS When Using Template "Deploy a Docker Application for Linux"?
- What Should I Do If the Connection Times Out Occasionally During a Deployment on a Windows Host?
Custom Application Actions
Health Test via URLs
- Incorrect URL
- URL Does Not Exist
- Invalid URL
- Application Deployment Interruption
- Insufficient Permissions
- Parameters Contain Backslashes (\)
- No Host Exists in the Environment
- Environment Does Not Exist
- Failed to Deploy an Application on a Windows Host
- Error Occurs During Application Deployment with the sudo Privileges
- Deployment Blocked by Third-Party Antivirus Software
- Invalid Path
- A Network Error Occurs During Software Installation on CentOS
- A Network Error Occurs During Software Installation on Ubuntu OS
- Windows Path Not Allowed on a Linux Host
Selecting Deployment Sources
- Software Package Not Found in CodeArts Artifact
- No Software Package Available for a Build Task
- URL Domain Name Resolution Failure
- File Download Times Out
- Inconsistent SHA256 Values in a File
- Inconsistent MD5 Values in a File
- Error "More than 100 build files"
- "HTTP Error 403" Is Displayed When the CodeArts Artifact Software Package Is Downloaded
- Invalid Path
Stopping a Service
- Incorrect Port Number
- Action Stop Service Deployed Successfully, But the Service Is Still in Started State
- Invalid Path
Copying a File
- File to Be Copied Does Not Exist
- Invalid File Path
- File or File Path Does Not Exist
- Action Copy Files Deployed Successfully, But the Expected Result Is Not Achieved
- Log Contains "copy File Failed" When Copying Files Between Linux Environment
- Log Contains "Windows does not support copying files between hosts" When Copying Files Between Windows Environment
- Log Contains "Hosts using secret key credit do not support copying files between" When Copying Files Between Environment
- Invalid Path
Deleting a File
- Cannot Delete Files on a Linux Host
- File Path Does Not Exist on a Windows Host
- Incorrect File Path on a Windows Host
- Invalid Path
Decompressing a File
- File to Be Decompressed Does Not Exist
- Backslashes (\) Are Used as Path Separators in the Native Command Compress-Archive
- Invalid Path
Modifying a Configuration File
- Invalid Path
Starting or Stopping Tomcat
- Invalid Tomcat Path
- Stopping Failed
- Startup Failed
- Environment Variables Are Not Configured
- Service Is Not Started Despite Successful Action Deployment
- Invalid Path
Starting/Stopping Go Service
- The Go Service Path Is Incorrect
- Startup Failed
- Deployment Is Successful, But the Service Is Not Started
- Invalid Path
Starting or Stopping Spring Boot
- Start/Stop Spring Boot
- Invalid Spring Boot Path
- Startup Failed
- Spring Boot Can Still Be Detected After Being Stopped (on Windows)
- Invalid Path
Starting or Stopping Nginx
- Nginx Gets Restarted Repeatedly
- Invalid Windows Host Path
- Deploying the Command for Stopping Nginx When Nginx Is Not Started
- Incorrect Format of the Nginx Configuration File
- Configuration File Backup Path Does Not Exist
- Starting or Stopping IIS
Starting or Stopping Node.js
- Node.js Fails to Be Started or Stopped on a Linux Host
- Node.js Fails to Be Started or Stopped on a Windows Host
- Invalid Path
Running Shell Commands
- A Message Indicating an Operation Failure Is Displayed During Action Run Shell Commands Deployment
- Service Is Not Started But the Log Shows That Shell Commands Are Successfully Executed
- Unidentified Shell Commands Are Used
- Shell Command References a File or Folder That Does Not Exist
- How Does a Shell Command Reference Parameters?
- Deployment of the Action Run Shell Commands Times Out
- Interactive Shell Commands Are Used
- Shell Command Deployment Times Out After the su Command Is Executed to Switch the User
- Invalid Path
- Other FAQs
Running Shell Scripts
- Running Shell Scripts Failed
- Deployment Is Successful But Does Not Achieve the Expected Result
- Invalid Path
Running PowerShell Commands
- Deployment of the Action Run PowerShell Commands Times Out
- Unidentified PowerShell Commands Are Used
- PowerShell Command References a File or Folder That Does Not Exist
- How Does a PowerShell Command Reference Parameters?
- Invalid Path
Running PowerShell Scripts
- Running PowerShell Scripts Failed
- Invalid Path
Running Docker Commands
- Docker Not Installed
- Docker Command Parameter Error
- No Deployment Permissions
- Image Does Not Exist
- login Command Execution Failed
- build Command Execution Failed
- tag Command Execution Failed
- push Command Execution Failed
- run Command Execution Failed
- start, restart, stop, or rm Command Execution Failed
- rmi Command Execution Failed
- pull Command Execution Failed
- rm Command Execution Failed
- Connection Timed Out
- Invalid Path
Pending Execution
- Invalid Path
- FAQs About ServiceStage
FAQs About Kubernetes Deployment Tasks
- Parameter Referenced by {{}} in the Manifest File Is Not Defined in the Application
- Target File Does Not Exist in CodeArts Artifact
- Path of the Manifest File in CodeArts Artifact Is Incorrect
- kubeconfig File Is Incorrectly Configured
- kubectl Command Fails to Be Deployed
- Failed to Deploy Applications on Kubernetes
- Log Contains "Too many files to unzip" When CodeArts Repo Is Selected as the Manifest File Source During Kubernetes Deployment
- Error Message "File is too large" Displayed During Manifest File Source Selection for Kubernetes Deployment
Ansible
- Invalid Entry File Path
- Entry File Not Found
- Copy Module Error
- JSON Parameter Parsing Error
- Service Module in Playbook Scripts Fails to Start or Stop Services
- Ansible Application Deployment Fails
- What Should I Do When the "Do not use the delegate_to, connection, hosts command in the Ansible PlayBook script for executing the local computer" message Is displayed When Running Ansible?
- Invalid Path
Creating an IIS Site
- Physical Path of an Application Does Not Exist
- IIS Not Installed on the Host
- Invalid Path
- How Do I Check the IIS Function on the Local Host?
- Installing IIS
Installing JDK
- A JDK of the Same Version Already Exists on the Target Host
- Java Not Installed on the Target Host
- JDK Decompression Failed
- Cannot Install OpenJDK 8 on Ubuntu 14 or Earlier Versions
- The Deployment Result Is "Openjdk does not support arm"
- Software Version Detected on Windows Host Does Not Match the Installed Version
- Invalid Path
Installing Tomcat
- Deployment Failed
- Invalid Path
Installing Nginx
- No sudo Permissions
- No Permission to Access the Path
- Invalid Path
Installing Go
- Invalid Installation Path
- Invalid Path
Installing PHP
- Error Returned When Installing PHP as a Common User
- Some Dependency Packages Do Not Exist in the CentOS Yum Repository
- Download Fails Due to Network Disconnection from the CentOS Yum Source
- Download Fails Because Some Software Dependency Packages Are Missing for apt-get in Ubuntu
- Invalid Path
Installing Node.js
- Cannot Decompress Node Packages
- Installation Path Fails to Be Created
- Invalid Path
Installing Python
- Invalid Path
Installing/Uninstalling Docker
- Error Returned During the Deployment of the Action for Installing or Uninstalling Docker as a Common User
- Error Returned Even Though the Action for Installing or Uninstalling Docker Is Successfully Deployed
- Invalid Path
- Grayscale Release with Istio
Hosts
- Videos
Show all
This action aims to access a URL on a target host to test the service status. The following table shows the configuration information.
Parameter |
Description |
Action Name |
Name of an added deployment action. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./(). |
Environment |
Select a host cluster as the deployment object. |
Retries |
If a service does not start up when the health test reaches the maximum retry times, the service fails this test. |
Interval (s) |
Interval between two retries. |
Test Path |
Health test URL. Multiple URLs can be added. |
Action Control |
You can configure whether to enable this setting.
