- What's New
- Function Overview
- Getting Started
User Guide
- CodeArts Deploy Overview
- Purchasing and Authorizing CodeArts Deploy
- Accessing CodeArts Deploy Homepage
- Configuring the Host Cluster of CodeArts Deploy
Creating and Deploying an Application with a Blank Template
- Creating an Application with a Blank Template
Configuring Deployment Actions for an CodeArts Deploy Application
- Configuring Deployment Actions for Software Installation
Configuring Deployment Actions for Containers
- Deploying on Kubernetes
- Deploying an Application in Kubernetes (CCE Cluster) Using Manifest
- Deploying an Application in Kubernetes (CCE Cluster) Quickly
- Deploying an Application with a Custom Kubernetes Cluster
- Kubernetes Nginx-Ingress Grayscale Deployment (CCE Cluster)
- Deploying with Helm3
- Deploying an Application on ServiceStage 2.0
- Rolling Back ServiceStage Components
- Configure Deployment Actions for Starting or Stopping a Service
- Configuring Deployment Actions for File Operations
- Configuring Deployment Actions for Running Commands
- Configuring Other Deployment Actions
- Editing the Deployment Actions of the CodeArts Deploy Application
- Configuring Parameters of an Application
- Configuring an Environment
- Configuring Permissions for Different Roles
- Deploying an Application and Viewing the Result
- Configuring System Notifications
Creating and Deploying an Application Using a Preset Template
- Introduction to CodeArts Deploy Templates
- Creating and Deploying an Application Using ServiceStage
- Creating and Deploying an Application Using a Kubernetes Template
- Creating and Deploying an Application Using the Function Deployment Template
- Creating and Deploying an Application Using the Tomcat Template
- Creating and Deploying an Application Using the Spring Boot Deployment Template
- Creating and Deploying an Application Using the Docker Deployment Template (Linux)
- Creating and Deploying an Application Using the Django Template
- Creating and Deploying an Application Using the Node.js Template
- Creating and Deploying a Common Application by Running the Shell Script
- Creating and Deploying an Application Using the Go Application Deployment Template
- Creating and Deploying an Application Using the Vue Deployment Template
- Creating and Deploying an Application Using the Custom Template
- Querying Audit Logs (Optional)
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
Managing Host Clusters
- Creating a Host Cluster
- Querying a Host Cluster List
- Deleting a Host Cluster
- Modifying a Host Cluster
- Creating a Host Cluster (Recommended)
- Querying a Host Cluster List (Recommended)
- Querying a Host Cluster (Recommended)
- Editing a Host Cluster
- Deleting a Host Cluster (Recommended)
- Querying Information About the Environment Associated with a Host Cluster
- Querying the Basic Environment Information List of an Application
Managing Hosts
- Creating a Host
- Querying a Host List
- Querying Host Details
- Modifying a Host
- Deleting a Host
- Creating a Host (Recommended)
- Querying a Host List (Recommended)
- Querying Host Details (Recommended)
- Editing Host Information in a Host Cluster
- Deleting a Host from a Host Cluster
- Cloning Hosts to the Target Host Cluster in Batches
- Deleting Hosts from a Host Cluster in Batches
Managing Applications
- Obtaining an Application List
- Creating an Application Using a Template
- Obtaining the Details of an Application
- Deleting an Application
- Querying the Historical Deployment Records of a Specified Application in a Project by the Start Time and End Time
- Obtaining an Application List (Recommended)
- Creating an Application (Recommended)
- Updating an Application
- Obtaining Application Details (Recommended)
- Deleting an Application (Recommended)
- Querying the Execution Parameters of a Deployment Record
- Cloning an Application
- Deleting Applications from a Project in Batches
- Checking Whether an Application with the Same Name Exists in a Project
- Disabling and Enabling an Application
- Managing Application Groups
- Managing Application Permissions
- Measuring Deployment Record
Managing Environments
- Creating an Environment for an Application
- Querying an Environment List of an Application
- Editing an Environment in an Application
- Deleting an Environment from an Application
- Querying Environment Details
- Importing a Host to an Environment
- Deleting a Host from an Environment
- Querying a Host List in an Environment
- Managing Host Cluster Permissions
- Managing Environment Permissions
- Application Examples
- Appendixes
Hosts
- What Are the Troubleshooting Methods for Host and Proxy Connectivity Verification Failures
- What Should I Do If Application Deployment Fails with "tomcat | Download War in url path" Displayed in Logs?
- Why Does a Task Fail on an Ubuntu Host After Being Successfully Run on a CentOS Host?
- What Should I Do If the No Host or Environment Whose Connectivity Has Been Verified?
- What Are Possible Causes of a Host verification failure?
- What Should I Do If a Draft Application Cannot Be Deployed?
- What Are Error Messages Displayed During Application Deployment?
- How Do I Find the Cause of an Application Deployment Error in Logs?
- What Should I Do If Error 403 Displayed During Application Deployment That Requires CCE Resources, Indicating Insufficient Permission?
- How Do I Roll Back a Deployed Version?
- What Should I Do If an Application Deployment Times Out?
- Does CodeArts Deploy Provide Batch and Incremental Deployment Policies?
- Do I Need to Upload a Software Package to CodeArts Artifact Before Deployment?
- Can I Deploy Web Pages Written in HTML or JS?
- How Do I Upload an Image for Container Deployment?
- Can I Use a Host to Deploy Multiple Projects?
- Do I Need to Install a Running Environment (Tomcat, Python, etc.) on the Target Host Before Deploying an Application?
- What Should I Do If Application Deployment Fails, with the Message "AnsibleUndefinedVariable: 'xxxx' is undefined" Displayed?
- What Should I Do If Application Deployment Succeeds But the Application Verification URL Cannot Be Accessed?
- What Should I Do If Application Deployment Fails Due to a DNS Resolution Error?
- What Should I Do If JDK Has Been Installed and Environment Variables Have Been Configured, But Application Deployment Fails with the Error Message "please configure JDK environment variables" Displayed?
- What Should I Do If the Log Indicates Insufficient Permissions?
- What Should I Do If the Path Is Invalid?
- What Should I Do If the System Displays a Message Indicating That No Hosts Are Found in the Environment?
- What Should I Do If an Error Is Reported When the Sudo Permission Is Used?
- What Should I Do If the File or File Path Does Not Exist?
- What Should I Do If I Have Insufficient Permissions?
- What Should I Do If the File Path Does Not Exist?
- What Should I Do If the Action "Create and Start Container" Fails on Ubuntu 22 OS When Using Template "Deploy a Docker Application for Linux"?
- What Should I Do If the Connection Times Out Occasionally During a Deployment on a Windows Host?
Custom Application Actions
Health Test via URLs
- Incorrect URL
- URL Does Not Exist
- Invalid URL
- Application Deployment Interruption
- Insufficient Permissions
- Parameters Contain Backslashes (\)
- No Host Exists in the Environment
- Environment Does Not Exist
- Failed to Deploy an Application on a Windows Host
- Error Occurs During Application Deployment with the sudo Privileges
- Deployment Blocked by Third-Party Antivirus Software
- Invalid Path
- A Network Error Occurs During Software Installation on CentOS
- A Network Error Occurs During Software Installation on Ubuntu OS
- Windows Path Not Allowed on a Linux Host
Selecting Deployment Sources
- Software Package Not Found in CodeArts Artifact
- No Software Package Available for a Build Task
- URL Domain Name Resolution Failure
- File Download Times Out
- Inconsistent SHA256 Values in a File
- Inconsistent MD5 Values in a File
- Error "More than 100 build files"
- "HTTP Error 403" Is Displayed When the CodeArts Artifact Software Package Is Downloaded
- Invalid Path
Stopping a Service
- Incorrect Port Number
- Action Stop Service Deployed Successfully, But the Service Is Still in Started State
- Invalid Path
Copying a File
- File to Be Copied Does Not Exist
- Invalid File Path
- File or File Path Does Not Exist
- Action Copy Files Deployed Successfully, But the Expected Result Is Not Achieved
- Log Contains "copy File Failed" When Copying Files Between Linux Environment
- Log Contains "Windows does not support copying files between hosts" When Copying Files Between Windows Environment
- Log Contains "Hosts using secret key credit do not support copying files between" When Copying Files Between Environment
- Invalid Path
Deleting a File
- Cannot Delete Files on a Linux Host
- File Path Does Not Exist on a Windows Host
- Incorrect File Path on a Windows Host
- Invalid Path
Decompressing a File
- File to Be Decompressed Does Not Exist
- Backslashes (\) Are Used as Path Separators in the Native Command Compress-Archive
- Invalid Path
Modifying a Configuration File
- Invalid Path
Starting or Stopping Tomcat
- Invalid Tomcat Path
- Stopping Failed
- Startup Failed
- Environment Variables Are Not Configured
- Service Is Not Started Despite Successful Action Deployment
- Invalid Path
Starting/Stopping Go Service
- The Go Service Path Is Incorrect
- Startup Failed
- Deployment Is Successful, But the Service Is Not Started
- Invalid Path
Starting or Stopping Spring Boot
- Start/Stop Spring Boot
- Invalid Spring Boot Path
- Startup Failed
- Spring Boot Can Still Be Detected After Being Stopped (on Windows)
- Invalid Path
Starting or Stopping Nginx
- Nginx Gets Restarted Repeatedly
- Invalid Windows Host Path
- Deploying the Command for Stopping Nginx When Nginx Is Not Started
- Incorrect Format of the Nginx Configuration File
- Configuration File Backup Path Does Not Exist
- Starting or Stopping IIS
Starting or Stopping Node.js
- Node.js Fails to Be Started or Stopped on a Linux Host
- Node.js Fails to Be Started or Stopped on a Windows Host
- Invalid Path
Running Shell Commands
- A Message Indicating an Operation Failure Is Displayed During Action Run Shell Commands Deployment
- Service Is Not Started But the Log Shows That Shell Commands Are Successfully Executed
- Unidentified Shell Commands Are Used
- Shell Command References a File or Folder That Does Not Exist
- How Does a Shell Command Reference Parameters?
- Deployment of the Action Run Shell Commands Times Out
- Interactive Shell Commands Are Used
- Shell Command Deployment Times Out After the su Command Is Executed to Switch the User
- Invalid Path
- Other FAQs
Running Shell Scripts
- Running Shell Scripts Failed
- Deployment Is Successful But Does Not Achieve the Expected Result
- Invalid Path
Running PowerShell Commands
- Deployment of the Action Run PowerShell Commands Times Out
- Unidentified PowerShell Commands Are Used
- PowerShell Command References a File or Folder That Does Not Exist
- How Does a PowerShell Command Reference Parameters?
- Invalid Path
Running PowerShell Scripts
- Running PowerShell Scripts Failed
- Invalid Path
Running Docker Commands
- Docker Not Installed
- Docker Command Parameter Error
- No Deployment Permissions
- Image Does Not Exist
- login Command Execution Failed
- build Command Execution Failed
- tag Command Execution Failed
- push Command Execution Failed
- run Command Execution Failed
- start, restart, stop, or rm Command Execution Failed
- rmi Command Execution Failed
- pull Command Execution Failed
- rm Command Execution Failed
- Connection Timed Out
- Invalid Path
Pending Execution
- Invalid Path
- FAQs About ServiceStage
FAQs About Kubernetes Deployment Tasks
- Parameter Referenced by {{}} in the Manifest File Is Not Defined in the Application
- Target File Does Not Exist in CodeArts Artifact
- Path of the Manifest File in CodeArts Artifact Is Incorrect
- kubeconfig File Is Incorrectly Configured
- kubectl Command Fails to Be Deployed
- Failed to Deploy Applications on Kubernetes
- Log Contains "Too many files to unzip" When CodeArts Repo Is Selected as the Manifest File Source During Kubernetes Deployment
- Error Message "File is too large" Displayed During Manifest File Source Selection for Kubernetes Deployment
Ansible
- Invalid Entry File Path
- Entry File Not Found
- Copy Module Error
- JSON Parameter Parsing Error
- Service Module in Playbook Scripts Fails to Start or Stop Services
- Ansible Application Deployment Fails
- What Should I Do When the "Do not use the delegate_to, connection, hosts command in the Ansible PlayBook script for executing the local computer" message Is displayed When Running Ansible?
- Invalid Path
Creating an IIS Site
- Physical Path of an Application Does Not Exist
- IIS Not Installed on the Host
- Invalid Path
- How Do I Check the IIS Function on the Local Host?
- Installing IIS
Installing JDK
- A JDK of the Same Version Already Exists on the Target Host
- Java Not Installed on the Target Host
- JDK Decompression Failed
- Cannot Install OpenJDK 8 on Ubuntu 14 or Earlier Versions
- The Deployment Result Is "Openjdk does not support arm"
- Software Version Detected on Windows Host Does Not Match the Installed Version
- Invalid Path
Installing Tomcat
- Deployment Failed
- Invalid Path
Installing Nginx
- No sudo Permissions
- No Permission to Access the Path
- Invalid Path
Installing Go
- Invalid Installation Path
- Invalid Path
Installing PHP
- Error Returned When Installing PHP as a Common User
- Some Dependency Packages Do Not Exist in the CentOS Yum Repository
- Download Fails Due to Network Disconnection from the CentOS Yum Source
- Download Fails Because Some Software Dependency Packages Are Missing for apt-get in Ubuntu
- Invalid Path
Installing Node.js
- Cannot Decompress Node Packages
- Installation Path Fails to Be Created
- Invalid Path
Installing Python
- Invalid Path
Installing/Uninstalling Docker
- Error Returned During the Deployment of the Action for Installing or Uninstalling Docker as a Common User
- Error Returned Even Though the Action for Installing or Uninstalling Docker Is Successfully Deployed
- Invalid Path
- Grayscale Release with Istio
Hosts
- Videos
This section describes how to set application parameters. By setting application parameters, you can deploy applications based on customized parameters.
Application parameters are classified into the following types:
- Custom: Add parameters as required. Parameter types include string, enumeration, and environment.
- Predefined: The parameter values are generated and cannot be deleted or modified.
Creating and Configuring a Parameter
This section describes how to create and configure user-defined parameters in an application.
- Select the target application, click
, and click Edit. The Deployment Actions page is displayed.
- Click Parameters.
The following parameters are provided.
Basic Information
Create Parameter
You can click Create Parameter to add a parameter.
Name
Parameter name. You can change the name of a custom parameter.
The name of a custom parameter cannot be the same as that of a predefined parameter.
Type
Default Value
Enter or select a parameter value.
If no environment is available when you select an environment type, you need to manually create an environment.
Private Parameter
If a parameter is private, the system encrypts the input for storage and only decrypts the parameter when using it. Runtime Settings cannot be set.
Runtime Settings
If this parameter is enabled, the parameter value can be changed during application deployment and the parameter value will be reported to the application. Runtime parameters need to be entered during execution.
Parameter description.
Operation
Click
to delete a parameter.
- Click Create Parameter to add a parameter. Customize the parameter name, type (String by default), and default value as required, and set private parameters and runtime settings.
- String
The parameter value is a character string. You can customize the value in the Default Value column, and enable the private parameter or runtime settings.
- Enumeration
After you set the type to Enumeration, the enumeration dialog box is displayed for you to set Available Values. To set multiple values, click the
icon. To delete a value, click
After the setting, select a value from the Default Value drop-down list, as shown in the following figure.
- Environment
Select an environment from the Default Value drop-down list. You can select an environment created in the application from the drop-down list.
If there is no option in the drop-down list, create an environment on the Environment Management tab page. Then return to the parameter configuration page and click
to refresh the environment to the drop-down list.
- String
- After modifying all information, click Save.
Editing a Parameter
- Click Parameters.
- Edit a parameter.
You can edit Name, Type, Default Value, Private Parameter, Runtime Settings, and Description of the existing parameters. You can also click
to drag parameters to change their order.
- Add a parameter.
Click Create Parameter to add a parameter. You can also click
in the Operation column to add a new parameter and edit it under the current parameter.
- Delete a parameter.
- Edit a parameter.
Using a Parameter
This section uses an example to describe how to use custom parameters.
- Click Parameters, create custom parameters of Environment, Enumeration, and String respectively and enable their Runtime Settings.
- Click Deployment Actions and reference custom parameters in the actions details.
The parameter reference format is ${Parameter name}. Enter $ in the text box and the parameter list will be displayed. Select the parameter as required.
For example, when configuring the Software Package item, enter $ to display the configured package_url parameter, and then select this parameter.
- Click Save and Deploy. In the dialog box that is displayed, assign values to the parameters again.
- Click OK to save and deploy the application.
- When CodeArts Pipeline is associated with an application, parameters can be dynamically bound.
- When CodeArts Pipeline is running, the entered parameter values will be replaced in the application and run.
- After you add a task action of the deployment type to the pipeline task and select an application with Runtime Settings parameters, parameters can be dynamically configured when the pipeline is executed.
