Updated on 2026-01-21 GMT+08:00
Creating IIS Site
What Is IIS?
IIS is short for Internet Information Services.
It is a service and a component of the Windows 2000 Server series. Different from common applications, IIS is a part of the operating system like a driver. It is started when the system is started.
Creating an IIS Site on a Windows Host
  1. Create an application by referring to Creating an Application.
  2. On the Deployment Actions page, add this deployment action based on the service scenario.
  3. Configure the action using the parameters described in the table below.
    Table 1 Parameters
    Action Name
    Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./()
    Environment
    Deployment object. Select an environment whose resource type is host cluster.
    Application Pool
    Application pool of IIS.
    .Net CLR Version
    Version of .Net CLR.
    Website Name
    Name of the website.
    Port
    The (listening) port that is bound.
    Physical Path
    Physical path of the application.
    Log Path
    Log path of the IIS running site.
    Action Control
    Whether to enable the settings.
    • Keep running on failure: Continue the task even if this action fails.
  1. Select a Windows environment for the application.
  2. Check whether the IIS version of the Windows host where the application is to be performed is later than 7.0. The procedure is as follows:
    a. Press Windows+R to open the Run dialog box, enter the inetmgr command for opening the IIS management window, and click OK.
    b. Start Internet Information Services (IIS) Manager, and then choose Help > About Internet Information Services.
    c. View the IIS version in the displayed dialog box.
    If the IIS version of the Windows host where the application is to be performed is earlier than or is 7.0, upgrade the IIS.
  3. Enter the physical path and log path of the application.
  4. Enter the .Net CLR Version of the target Windows host.
    • Find clever.exe in C:\Program Files\Microsoft SDKs\Windows\v7.0A\bin or C:\Program Files\Microsoft SDKs\Windows\v8.0A\bin\NETFX 4.0 Tools.
    • Run the program in the cmd window to obtain the version supported by the .NET CLR.
    If the clever.exe program cannot be found, download and install it.
  5. Enter the application pool name and website name.
  6. Specify a port (the port bound) and deploy the application.
Helpful Links
If you encounter any problem during deployment, see Creating an IIS Site.
