Deploying with Helm3
Helm is a Kubernetes package management tool, which is similar to the package manager in Linux, such as YUM and APT. Helm can easily deploy packaged YAML files on Kubernetes. Helm 3 is the commonly used and stable version of Helm.
CodeArts Deploy allows you to use Helm to deploy and upgrade Kubernetes clusters.
- Create an application by referring to Creating an Application.
- On the Deployment Actions page, add this deployment action based on the service scenario.
- Configure the action using the parameters described in the table below.
Table 1 Parameters Parameter
Action Name
Mandatory. Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./()
Cluster Type
The default value is Custom.
Kubernetes Service Endpoint
Mandatory. You can select a CCE cluster or your own Kubernetes cluster.
- Huawei Cloud CCE cluster
- Create a CCE cluster.
- Create a namespace.
- Select the CCE cluster to be deployed.
- Your own Kubernetes cluster
Configure the kubeconfig file and select the cluster for deployment.
Helm Version
Mandatory. Select a Helm version. The default value is helm-3.4.1.
Helm Command
Mandatory. install, upgrade, and uninstall are available.
If you select upgrade for Helm Command and the chart name does not exist, the system automatically runs install.
Namespace
Mandatory. Enter a namespace name.
Chart Name
Mandatory. The custom chart name. You can perform the upgrade operation on the same chart name.
Chart Package Source
Mandatory. Select the source of the chart package to be installed. Artifact and Repo are available.
If you select Repo, you need to specify the code repository and branch.
Chart Package
This parameter is mandatory when Chart Package Source is set to Artifact.
Enter a directory or GZIP package with a chart file structure.
Chart Package Path
This parameter is mandatory when Chart Package Source is set to Repo.
Enter the path of the directory or GZIP package with a chart file structure.
Values File Path
When Chart Package Source is set to Artifact, you can select Values files or folders containing Values files from artifact repositories.
When Chart Package Source is set to Repo, you can switch to Repo under Values Source and enter the path of the corresponding Values file or folder.
For example, if you specify Myvalues.yaml, -f Myvalues.yaml will be added to Helm Command Parameters.
Specify Values Files
If the Values file path is a folder, enter the file relative path. Use commas (,) to separate multiple file paths, for example, values1.yaml,values2.yaml.
Values
Set values for the selected command. If you specify key1=val1,key2=val2 (separate values with commas), -set key1=val1,key2=val2 will be added to Helm command parameters.
Add other content to using Helm command parameters.
For details, see Helm Install, Helm Upgrade, and Helm Uninstall.
Action Control
Continue the task even if this action fails.
Environment Preparation for Helm3 Deployment Example
This section uses the chart directory as an example to describe how to prepare the environment for the subsequent three examples. Use the following template for CCE cluster-based deployment and create the following directories in a code repository of CodeArts Repo.
Segment in configmap.yaml
name: {{ .Values.configmapname }} Segment in deployment.yaml
template:
containers:
- image: '{{ .Values.imagename }}:{{ .Values.imagetag }}' Segment in values.yaml
configmapname: valuesfromfile imagename: httpd imagetag: latest
{{.Values.xxxx}} corresponds to the variable defined in the values.yaml file in the chart.
The following three examples are based on this section.
For details, see Values Files.
- Example 1: Using the chart package or chart file structure directory
If the default values file exists in the chart, you do not need to specify the values file in Artifact. You can directly deploy the default values file.
The deployment result is as follows.
The corresponding ConfigMap generated on the CCE console is as follows.
The corresponding Deployment generated on the CCE console is as follows.
- Example 2: Specifying the values file in CodeArts Artifact
This example demonstrates how to use the Values file in Artifact for deployment.
The values defined in the external values file will overwrite the values defined in the Values file in the chart.
Segment of an external Values file. In this example, the file is named values123.yaml.
configmapname: valuesfile-releasenman imagename: nginx imagetag: stable
As shown in the following figure, for Values File, select the Values file in Artifact.
- Example 3: Deploying Helm3 by configuring values
If Values is set, it has the highest priority and overwrites the values set in the values file of Chart and the values set in the external values file.
The following figure describes how to configure the image version.
Segment of the Values File in Chart Package:
imagetag: latest
Segment of Values File in Artifact:
imagetag: stable
When setting Values, enter the following information:
imagetag=perl
