Starting or Stopping the Go service
This action aims to start or stop a service in a specified path.
Parameter |
Description |
Action Name |
Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./() |
Environment |
Deployment object. Select an environment whose resource type is host cluster. |
Operation |
Start and Stop are available. |
Absolute Path |
Installation path of Go. |
Waiting Time |
Time for waiting for the service to start. If you choose to start the service, the system checks the process during the startup to determine whether the service is started successfully. You can adjust the time based on the actual time required for starting the service. If the time is improper, the detection fails. |
Action Control |
You can configure whether to enable the settings.
