Updated on 2025-08-13 GMT+08:00
Rolling Back ServiceStage Components
This action aims to roll back an instance snapshot deployed on ServiceStage.
After a version is rolled back, instances of later versions are overwritten and cleared.
Table 1 Parameters
Action Name
Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./()
Region
Region where ServiceStage is deployed.
Deployment System
Supports Container deployment, AS Group, and ECS.
Application
Select the application created in ServiceStage.
Component
Select the component to be deployed.
Environment
Select the environment to be deployed.
Component Instance
Select the component instance to be deployed.
Instance Snapshot
Select a snapshot version.
Action Control
Continue the task even if this action fails.
This action is not applicable to the LA-Mexico City2 and AP-Singapore regions.
