Installing Python
Add this action to install Python on a host. The following table describes the configuration parameters.
Configuring Deployment Actions
- Create an application by referring to Creating an Application.
- On the Deployment Actions page, add this deployment action based on the service scenario.
- Configure the action using the parameters described in the table below.
Table 1 Parameters Parameter
Action Name
Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./()
Environment
Deployment object. Select an environment whose resource type is host cluster.
Python Version
Python version.
Installation Path
Installation path of Python.
Action Control
Whether to enable the settings.
- Keep running on failure: Continue the task even if this action fails.
- Execute this action with the sudo permission: Use the sudo permission to deploy this action.
Helpful Links
If you encounter any problems during deployment, see Installing Python.
