- What's New
- Billing
- Getting Started
- User Guide
- API Reference
- SDK Reference
DeH FAQs
- What Is DeH?
- When a DeH Is Needed?
- Can I Use DeHs to Build Websites?
- Can I Buy DeHs by Myself?
- What Hypervisor Is Used by DeHs?
- Does Each DeH Have a Unique ID?
- What Are the Differences Between DeHs and BMSs?
- What Are the Differences Between DeH and DeC?
- What Are the Differences Between DeHs and ECSs?
- How Can I Query the Number of Available Resources on a DeH?
- Why Is It Not Possible to Successfully Create an ECS on a DeH Even When There Are More Available Resources on the DeH Than What the ECS Requires?
- Does DeH Support Capacity Expansion?
- What Is BYOL?
- How Do I Bring My Own Licenses to a DeH?
- Can I Attach an EVS Disk to a DeH?
- Is There a Limit on the Number of DeHs That I Can Purchase?
ECS FAQs
- What Are the Differences Between ECSs on DeHs and Those on Shared Hosts?
- What Are the Restrictions on Creating ECSs on a DeH?
- Can I Create ECSs of Different Flavors on a DeH?
- Can I Modify the Specifications of ECSs on DeHs?
- What Should I Do If I Fail to Create an ECS on a DeH?
- Can I Migrate ECSs in Resource Pools to DeHs?
- Billing FAQs
DeH FAQs
- Videos
- Glossary
More Documents
User Guide (Paris Region)
- Product Introduction
- Getting Started
- DeH Management
- ECS Management
- Tag Management
- Key Operations Recorded by CTS
- Managing Enterprise Projects
- Permission Management
DeH FAQs
- What Is DeH?
- Can I Use DeHs Build Websites?
- Can I Allocate DeHs by Myself?
- What Is BYOL?
ECS FAQs
- Billing FAQs
DeH FAQs
- Change History
- API Reference (Paris Region)
On this page
Show all
Help Center/
Dedicated Host/
User Guide/
Key Operations Recorded by CTS/
Key DeH Operations Recorded by CTS
Cloud Trace Service (CTS) is a log audit service intended for security. It allows you to collect, store, and query cloud resource operation records and use these records for security analysis, compliance auditing, resource tracking, and fault locating.
Table 1 describes the DeH operations that can be recorded by CTS.
Parent topic: Key Operations Recorded by CTS
