Tag Management
Tags are identifiers of DeHs and can help you quickly identify your DeHs.
You can add a tag to a DeH when creating a DeH. Alternatively, you can add a tag to a DeH on the Tags tab of the DeH details page. A maximum of 10 tags can be added to a DeH.
A tag consists of a tag key and a tag value. Table 1 lists the naming requirements for keys and values.
| Parameter | Requirement | Example Value |
| Tag key |
 | Organization |
| Tag value |
 | Apache |
Searching for DeHs
On the Dedicated Host page, you can search for the desired DeHs by tag key and tag value.
- Log in to the DeH console.
- In the upper right corner of the DeH list, click Search by Tag to show the search page.
    Figure 1 Searching for DeHs by tag
- Enter the tag key and tag value of the target DeH. Click Search.
    The system automatically searches for your desired DeHs.
- Click  to add a tag. to add a tag.You can add multiple tags to search for DeHs. The system will display DeHs that match all tags.
- Click Search.
    The system searches for DeHs based on tag keys or tag values.
