- What's New
- Billing
- Getting Started
- User Guide
- API Reference
- SDK Reference
DeH FAQs
- What Is DeH?
- When a DeH Is Needed?
- Can I Use DeHs to Build Websites?
- Can I Buy DeHs by Myself?
- What Hypervisor Is Used by DeHs?
- Does Each DeH Have a Unique ID?
- What Are the Differences Between DeHs and BMSs?
- What Are the Differences Between DeH and DeC?
- What Are the Differences Between DeHs and ECSs?
- How Can I Query the Number of Available Resources on a DeH?
- Why Is It Not Possible to Successfully Create an ECS on a DeH Even When There Are More Available Resources on the DeH Than What the ECS Requires?
- Does DeH Support Capacity Expansion?
- What Is BYOL?
- How Do I Bring My Own Licenses to a DeH?
- Can I Attach an EVS Disk to a DeH?
- Is There a Limit on the Number of DeHs That I Can Purchase?
ECS FAQs
- What Are the Differences Between ECSs on DeHs and Those on Shared Hosts?
- What Are the Restrictions on Creating ECSs on a DeH?
- Can I Create ECSs of Different Flavors on a DeH?
- Can I Modify the Specifications of ECSs on DeHs?
- What Should I Do If I Fail to Create an ECS on a DeH?
- Can I Migrate ECSs in Resource Pools to DeHs?
- Billing FAQs
DeH FAQs
- Videos
- Glossary
More Documents
User Guide (Paris Region)
- Product Introduction
- Getting Started
- DeH Management
- ECS Management
- Tag Management
- Key Operations Recorded by CTS
- Managing Enterprise Projects
- Permission Management
DeH FAQs
- What Is DeH?
- Can I Use DeHs Build Websites?
- Can I Allocate DeHs by Myself?
- What Is BYOL?
ECS FAQs
- Billing FAQs
DeH FAQs
- Change History
- API Reference (Paris Region)
Adjusting DeH Resource Quotas
What Is Quota?
Quotas can limit the number or amount of resources available to users, such as the maximum number of ECS or EVS disks that can be created.
If the existing resource quota cannot meet your service requirements, you can apply for a higher quota.
How Do I View My Quotas?
- Click
in the upper left corner and select the desired region and project.
- In the upper right corner of the page, choose Resources > My Quotas.
The Service Quota page is displayed.
Figure 1 My Quotas - View the used and total quota of each type of resources on the displayed page.
If a quota cannot meet service requirements, apply for a higher quota.
How Do I Apply for a Higher Quota?
Figure 2 My Quotas - Click Increase Quota in the upper right corner of the page.
Figure 3 Increasing quota
- On the Create Service Ticket page, configure parameters as required.
In the Problem Description area, fill in the content and reason for adjustment.
- After all necessary parameters are configured, select I have read and agree to the Ticket Service Protocol and Privacy Statement and click Submit.
