Modifying the Specifications of an ECS on a DeH
When the specifications of ECSs on a DeH cannot meet your service requirements, you can modify the ECS specifications including the vCPUs and memory.
- Log in to the DeH console.
- Click the name of the target DeH.
- On the ECSs on the DeH tab, view the status of the target ECS.
- Only the specifications of a stopped ECS can be modified. If the ECS is not stopped, click More and select Stop in the Operation column.
- After the ECS status changes to Stopped, click Modify Specifications in the Operation column.
The Modify ECS Specifications page is displayed. Modify the specifications by following the instructions described in Elastic Cloud Server User Guide.
