Managing an ECS on a DeH
You can start, stop, restart, or delete an ECS on a DeH on the management console.
- Click
in the upper left corner and select the desired region and project.
- Under Compute, click Dedicated Host.
The Dedicated Host page is displayed.
- Click the name of the target DeH.
- On the ECSs on the DeH tab, locate the target ECS and select the target option in the Operation column to manage the ECS. Alternatively, select the target ECS and select an operation above the ECS list.
The options are as follows:
- Modify Specifications (allowed only when ECSs are stopped)
- Start (allowed only when ECSs are stopped)
- Stop (allowed only when ECSs are running)
- Restart (allowed only when ECSs are running)
- Delete (If Permanently delete is selected, the ECSs will be deleted permanently. If Permanently delete is not selected, the ECSs are temporarily stored in the recycle bin. ECSs in the recycle bin still occupy the quotas.)
Related Operations
On the ECSs on the DeH tab page, you can also click Buy to create ECSs.
For details, see Purchasing an ECS.
- When selecting an ECS type, pay attention to mapping between the ECS type and the DeH type. If no matched DeH resources exist, ECSs cannot be created.
- Currently, you can deploy only pay-per-use ECSs on DeHs.
