Configuring Auto Placement for DeHs
You can enable or disable auto-placement for each DeH to control whether ECSs can be automatically allocated to a DeH.
- Log in to the DeH console.
- Click the name of the target DeH and enable or disable Auto Placement.
Verification
Assume that you have two DeHs with Auto Placement enabled. The vCPUs and Memory (GB) values of DeH A are 83/100 and 167/232, and those of DeH B are 100/100 and 232/232. When creating an ECS, enable Auto placement for DeH. Then the system automatically creates the ECS on DeH B to balance the load among the two DeHs.
