- What's New
- Billing
- Getting Started
- User Guide
- API Reference
- SDK Reference
DeH FAQs
- What Is DeH?
- When a DeH Is Needed?
- Can I Use DeHs to Build Websites?
- Can I Buy DeHs by Myself?
- What Hypervisor Is Used by DeHs?
- Does Each DeH Have a Unique ID?
- What Are the Differences Between DeHs and BMSs?
- What Are the Differences Between DeH and DeC?
- What Are the Differences Between DeHs and ECSs?
- How Can I Query the Number of Available Resources on a DeH?
- Why Is It Not Possible to Successfully Create an ECS on a DeH Even When There Are More Available Resources on the DeH Than What the ECS Requires?
- Does DeH Support Capacity Expansion?
- What Is BYOL?
- How Do I Bring My Own Licenses to a DeH?
- Can I Attach an EVS Disk to a DeH?
- Is There a Limit on the Number of DeHs That I Can Purchase?
ECS FAQs
- What Are the Differences Between ECSs on DeHs and Those on Shared Hosts?
- What Are the Restrictions on Creating ECSs on a DeH?
- Can I Create ECSs of Different Flavors on a DeH?
- Can I Modify the Specifications of ECSs on DeHs?
- What Should I Do If I Fail to Create an ECS on a DeH?
- Can I Migrate ECSs in Resource Pools to DeHs?
- Billing FAQs
DeH FAQs
- Videos
- Glossary
More Documents
User Guide (Paris Region)
- Product Introduction
- Getting Started
- DeH Management
- ECS Management
- Tag Management
- Key Operations Recorded by CTS
- Managing Enterprise Projects
- Permission Management
DeH FAQs
- What Is DeH?
- Can I Use DeHs Build Websites?
- Can I Allocate DeHs by Myself?
- What Is BYOL?
ECS FAQs
- Billing FAQs
DeH FAQs
- Change History
- API Reference (Paris Region)
On this page
Show all
Viewing the Details of a DeH
You can view the basic information about a DeH, including the status, total resources, and usage, on the DeH console.
- Click
in the upper left corner and select the desired region and project.
- Under Compute, click Dedicated Host.
The Dedicated Host page is displayed.
- Locate the target DeH and view the following information:
- Name: DeH name
- Type: DeH type
- AZ: AZ where DeHs are located
- Auto Placement: Whether Auto Placement is enabled.
- Status: DeH status
- vCPUs: Total number of vCPUs and available vCPUs
- Memory(GiB): Total memory and available memory
- Sockets: Number of physical CPU sockets
- Cores: Number of physical cores
- Billing Mode: How a DeH is billed.
Related Operations
Parent topic: DeH Management
