Updated on 2026-08-04 GMT+08:00
Unsupported DML Statements
Table 1 Syntax restrictions on DML
DML Syntax
Constraint
DELETE statement
PARTITION clauses are not supported.
UPDATE statement
Cross-shard subquery is not supported.
SELECT statement
ORDER BY statement. User-defined sequencing similar to ORDER BY FIELD(id,1,2,3) is not supported.
When the queried table is a sharded table, you cannot obtain the expected result.
