Key Operations Recorded by CTS
Cloud Trace Service (CTS) records operations related to DDM for further query, audit, and backtrack.
| Operation | Resource Type | Trace Name |
| Applying a parameter template | parameterGroup | applyParameterGroup |
| Renewing a yearly/monthly DDM instance to changing the billing mode of a DDM instance from yearly/monthly to pay-per-use or from pay-per-use to yearly/monthly | all | bssArrearage |
| Updating DDM metadata | all | bssUpdateMetadata |
| Clearing metadata after a schema is scaled out | logicDB | cleanMigrateLogicDB |
| Clearing user resources | all | cleanupUserAllResources |
| Replicating a parameter template | parameterGroup | copyParameterGroup |
| Creating a DDM instance | instance | createInstance |
| Creating a schema | logicDB | createLogicDB |
| Creating a parameter template | parameterGroup | createParameterGroup |
| Creating an account | user | createUser |
| Deleting a DDM instance | instance | deleteInstance |
| Deleting a schema | logicDB | deleteLogicDB |
| Deleting a parameter template | parameterGroup | deleteParameterGroup |
| Deleting an account | user | deleteUser |
| Scaling out a DDM instance | instance | enlargeNode |
| Restarting a DDM instance | instance | instanceRestart |
| Importing schema information | instance | loadMetadata |
| Switching the route during scaling | logicDB | manualSwitchRoute |
| Scaling out a schema | logicDB | migrateLogicDB |
| Modifying a parameter template | parameterGroup | modifyParameterGroup |
| Changing the route switching time | logicDB | modifyRouteSwitchTime |
| Modifying an account | user | modifyUser |
| Scaling in a DDM instance | instance | reduceNode |
| Resetting a parameter template | parameterGroup | resetParameterGroup |
| Resetting the password of an account | user | resetUserPassword |
| Change instance specifications | instance | resizeFlavor |
| Restoring DB instance data | instance | restoreInstance |
| Retrying to scale out a schema | logicDB | retryMigrateLogicDB |
| Rolling back the version upgrade of a DDM instance | instance | rollback |
| Rolling back a schema scale-out task | logicDB | rollbackMigrateLogicDB |
| Configuring access control | instance | switchIpGroup |
| Synchronizing data node information | instance | synRdsinfo |
| Upgrading the version of a DDM Instance | instance | upgrade |
| Adding a tag | instance | addTag |
| Deleting a tag | instance | deleteTag |
| Editing a tag | instance | modifyTag |
| Creating a node group | group | createGroup |
| Deleting a group | group | deleteGroup |
| Modifying the floating IP address | instance | modifyIp |
| Modifying the name of an instance | instance | modifyName |
| Restarting a node | node | nodeRestart |
| Exporting the instance list | instance | exportInstance |
| Reloading metadata | instance | reloadInstanceConfig |
| Changing a database port | instance | modifyInstancePort |
| Querying the flavor change list | instance | queryFlavor2Resize |
| Querying slow SQL statements | instance | listSlowLogs |
| Obtaining the instance version | instance | listDatabaseVersions |
| Querying slow log statistics | instance | querySlowLogAnalysis |
| Binding an EIP | instance | bindEIP |
| Unbinding an EIP | instance | unbindEIP |
| Obtaining information about the EIP bound to an instance | instance | queryEIP |
| Querying a CN session | instance | queryLogicalProcessList |
| Killing a CN session | instance | killLogicalProcess |
| Querying a DN session | instance | queryPhysicalProcessList |
| Killing a DN session | instance | killPhysicalProcess |
| Querying information about killed sessions | instance | queryKillProcessesAuditLog |
| Querying access control | instance | queryIpGroup |
| Obtaining the tag list | tag | listTags |
| Obtaining the instance tag list | instance | listInstanceTags |
| Enabling or disabling SSL for an instance kernel | instance | switchSsl |
| Obtaining the address for downloading the SSL certificate of an instance | instance | getSslCerts |
| Querying schemas | instance | listDatabases |
| Exporting schema information | instance | dumpMetadata |
| Querying the size of a schema | instance | queryLogicDbSize |
| Pre-verifying shard configuration | logicDB | preCheckMigrateLogicDb |
| Querying the shard configuration pre-verification results | instance | queryPreCheckMigrateLogicDb |
| Querying details about a shards configuration task | instance | queryMigrateTaskDetail |
| Updating the SQL blacklist of an instance | logicDB | configSqlBlackList |
| Obtaining the SQL blacklist | logicDB | querySqlBlacklist |
| Changing the read/write weight of an instance | instance | updateReadAndWriteStrategy |
| Changing the read/write weight of instances in batches | instance | batchModifyReadAndWriteStrategy |
| Querying whether to enable read/write splitting | instance | queryReadWriteSeparationSwitch |
| Enabling or disabling read/write splitting | instance | updateReadAndWriteStrategySwitch |
| Querying available data nodes of an instance | instance | ListAvailableRds |
| Querying data nodes associated with an instance | instance | queryRelatedRdsList |
| Querying available data nodes for shards configuration | logicDB | queryAvailableMigrateRdsList |
| Querying shards configuration actions for a schema | instance | queryMigrateAction |
| Querying kernel task execution logs | instance | listTaskLogs |
| Checking data node connectivity | instance | checkRdsConnection |
| Querying logical tables of a schema | logicDB | listLogicTables |
| Querying details of a logical table | table | showLogicTable |
| Querying a backup list | backup | listBackups |
| Deleting a backup | backup | deleteBackup |
| Querying backup details | backup | showBackup |
| Restoring metadata | instance | restoreMetaData |
| Querying the associated data node at a specified time point | instance | showBackupRelatedDn |
| Querying the restoration time | instance | queryRestoreTime |
| Querying RDS instances that can be restored | instance | queryRds4Restore |
| Querying instances that can be restored | instance | queryDDM4Restore |
| Checking whether the parameter group name exists | parameterGroup | checkConfigurationName |
| Querying parameter groups | parameterGroup | listConfigurations |
| Querying details about a parameter group | parameterGroup | showConfiguration |
| Querying instances that a parameter group of a template can be applied to | parameterGroup | queryApplicableInstances |
| Querying the parameter group change history | parameterGroup | queryModifyHistory |
| Querying application records of a parameter group of a template | parameterGroup | queryApplyHistory |
| Querying parameter groups of an instance | instance | showInstanceConfiguration |
| Querying the size of a logical table | logicDB | queryLogicTableSize |
| Verifying weak passwords | project | isWeakPassword |
| Querying read-only data nodes | dn | queryReadOnlyDBInstance |
| Querying the instance list | instance | listInstances |
| Querying details of a specified instance | instance | showInstance |
| Querying details about a schema | logicDB | showDatabase |
| Querying nodes of an instance | instance | listNodes |
| Querying details of an instance node | node | showNode |
| Querying accounts | instance | listUsers |
| Changing the security group of an instance | instance | updateInstanceSecurityGroup |
| Creating a slow query log download task | instance | createSlowLogDownload |
| Resetting an administrator account | instance | resetAdministrator |
| Querying downloaded slow query log information | instance | querySlowLogDownLoad |
| Querying the result of an asynchronous task | job | showJobResult |
| Querying the latest shard configuration task for a schema | logicDB | queryLatestMigrateJob |
| Querying DB engines | project | listEngines |
| Querying enterprise projects | project | listEnterpriseProjects |
| Querying the node class list | project | listFlavors |
