Updated on 2026-08-04 GMT+08:00
Task Center
You can view the progress and results of asynchronous tasks on the Task Center page.
Tasks That Can Be Viewed
The following tasks can be viewed:
- Creating a DDM instance
- Deleting a DDM instance
- Changing a node class
- Scaling out a DDM instance
- Scaling in a DDM instance
- Restarting a DDM instance
- Binding an EIP to a DDM instance
- Unbinding an EIP from a DDM instance
- Restoring data from current DDM instance
- Importing schema information
- Configuring shards
- Retrying shard configuration
- Deleting a backup
- Creating a node group
- Deleting a node group
- Restarting a node
- Upgrading the version of a DDM instance
- Downgrading the version of a DDM instance
- Rolling back the version
- Log in to the DDM console.
- Choose Task Center in the left navigation pane, locate the required task, and view its details.
- You can locate a task by name, order ID, or DB instance name/ID, or search for the required task by entering an instance ID in the search box in the upper right corner.
- You can click
in the upper right corner to search for tasks executed within a specific period. The default time range is seven days. All tasks in the list can be retained for up to one month.
- You can view the tasks that are in the following statuses:
- Running
- Completed
- Failed
- You can view the task creation and completion time.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
