Creating a Table
  - Do not create tables whose names start with _ddm. DDM manages such tables as internal tables by default
- Sharded tables do not support globally unique indexes. If the unique key is different from the sharding key, data uniqueness cannot be ensured.
- The auto-increment key should be of the BIGINT data type. To avoid duplicate values, do not use TINYINT, SMALLINT, MEDIUMINT, INTEGER, or INT as the auto-increment key.
Database and Table Sharding
The following is an example statement when HASH is used for database sharding and MOD_HASH for table sharding:
CREATE TABLE tbpartition_tbl ( id bigint NOT NULL AUTO_INCREMENT COMMENT 'Primary key id', name varchar(128), PRIMARY KEY(id) ) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci DBPARTITION BY HASH(id) TBPARTITION BY mod_hash(name) tbpartitions 8;
Database Sharding
The following is an example statement when HASH is used:
CREATE TABLE dbpartition_tbl ( id bigint NOT NULL AUTO_INCREMENT COMMENT 'Primary key id', name varchar(128), PRIMARY KEY(id) ) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci DBPARTITION BY HASH(id);
Creating a Broadcast Table
The following is an example statement:
CREATE TABLE broadcast_tbl ( id bigint NOT NULL AUTO_INCREMENT COMMENT 'Primary key id', name varchar(128), PRIMARY KEY(id) ) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci BROADCAST;
Creating a Table When Sharding Is not Used
A global sequence can also be specified for an unsharded table, but this function is always ignored. An unsharded table provides auto-increment using auto-increment values of corresponding physical tables.
CREATE TABLE single( id bigint NOT NULL AUTO_INCREMENT COMMENT 'Primary key id', name varchar(128), PRIMARY KEY(id) );
