Instance Statuses
The instance status indicates the running status of a DDM instance. You can view the status of your DDM instance on the management console.
| Category | Status | Description |
| Normal | Running | The DDM instance is normal and available. |
| Abnormal | Creation failed | The DDM instance failed to be created. |
| Abnormal | The DDM instance is unavailable. | |
| Some nodes abnormal | Some modes of the DDM instance are unavailable. | |
| Frozen | Instances are frozen when the account balance falls below zero. | |
| Actions in progress | Creating | The DDM instance is being created. |
| Backing up | The instance is being backed up. | |
| Restoring | The instance is being restored from a backup. | |
| Upgrading | The kernel version of the instance is being upgraded. | |
| Rolling back | The kernel version of the instance is being rolled back. | |
| Configuring SSL | SSL is being enabled for the instance. | |
| Changing the DDM service port | The service port of the DDM instance is being changed. | |
| Deleting | The DDM instance is being deleted. | |
| Restarting | The DDM instance is being restarted. | |
| Adding node | Nodes are being added to an instance. | |
| Deleting node | Nodes are being deleted from an instance. | |
| Changing instance class | The vCPUs and memory of the DDM instance are being changed. | |
| Changing to yearly/monthly | The billing mode of the instance is being changed to yearly/monthly. | |
| Creating a group | A node group is being created. | |
| Deleting a group | A node group is being deleted. | |
| Creating a schema | A schema is being created. | |
| Deleting a schema | A schema is being deleted. |
