Help Center/
      Distributed Database Middleware/
        User Guide/
        Connection Management/
      Modifying the Floating IP Address of a DDM Instance and a Group
        Updated on 2024-07-30 GMT+08:00
After load balancing is enabled for DDM, you can modify the floating IP addresses of your DDM instance and groups.
- Log in to the DDM console.
- On the Instances page, select the instance whose floating IP address you want to modify and click its name.
- In the Network Information area, click Modify beside the Floating IP Address field.
- In the displayed dialog box, enter an available IP address in the same VPC and subnet as the current floating IP address and click OK.
    Figure 1 Modifying the floating IP address
Modifying the Floating IP Address of a Group
- In the Group Information area, locate the group whose floating IP address you want to modify and choose More > Modify Floating IP Address in the Operation column.
    Figure 2 Group information
    Figure 3 Modifying the floating IP address
   Parent topic: Connection Management
