Changing a DDM Service Port
DDM allows you to change a service port of your DDM instance and will restart the instance after the change.
- Log in to the DDM console.
- On the Instances page, select the DDM instance whose service port you want to change and click its name.
- On the Basic Information page, in the Connection Information area, click
next to DDM Service Port. For DDM instances, the service port number ranges from 1025 to 65534 except for ports 1033, 7009, 8888, and 12017 because they are in use by DDM. The default value is 5066.
- Click
to apply the changes. - In the dialog box, click Yes. Changing the service port of a DDM instance requires a restart of the instance.
- In the dialog box, click No.
- View the results on the Basic Information page.
