Creating an Account
Multiple users with different permissions can be created to access a DB instance or a database. You can create an account with required permissions on the DDM console.
- Log in to the DDM console.
- In the instance list, locate the DDM instance that you want to create an account for and click its name.
- In the navigation pane, choose Accounts.
- On the displayed page, click Create Account and configure the required parameters.
Figure 1 Creating a DDM account
Table 1 Required parameters Parameter
Username
Username of the account.
The username can include 1 to 32 characters and must start with a letter. Only letters, digits, and underscores (_) are allowed.
Password
Password of the account. The password:
- Can include 8 to 32 characters.
- Must contain at least three of the following character types: lowercase letters, uppercase letters, digits, and special characters ~!@#%^*-_+?
- Cannot be a weak password. It cannot be overly simple and easily guessed.
- The password cannot be the same as username or username in reverse order.
Confirm Password
The confirm password must be the same as the entered password.
Password Validity (Days)
Password validity period. The value must be an integer ranging from 0 to 65535, in days. An expired account cannot be used to log in to the system. You need to reset the password and log in again. If an account is created using the administrator account by executing the CREATE USER statement, before you set the password validity period for this account, reset its password first.
- If the value is 0, the password never expires.
- If this parameter is not set, the password will always be valid.
NOTE:The DDM kernel version must be 3.0.4 or later.
Schema
Schema to be associated with the DDM account. You can select an existing schema from the drop-down list.
The account can be used to access only the associated schemas.
Permissions
Options: CREATE, DROP, ALTER, INDEX, INSERT, DELETE, UPDATE, and SELECT. You can select any or a combination of them.
Description of the account, which cannot exceed 256 characters.
- Confirm the settings and click OK.
