Updated on 2026-08-04 GMT+08:00
Introduction
DDM is compatible with the MySQL license and syntax, but the use of SQL statements is limited due to differences between distributed databases and single-node databases.
Before selecting a DDM solution, evaluate the SQL syntax compatibility between your application and DDM.
DDM EXPLAIN
If you add EXPLAIN before a SQL statement, you will see a specific execution plan when you execute the statement. You can analyze the time required based on the plan and modify the SQL statement for optimization.
Table 1 Common operators
Operator Name
ExtTableScan
This operator is optimized from LogicalTableScan, primarily targeting data retrieval, but it is not limited to full table scans.
Union
This operator can be used to combine the result-set of two or more queries.
HashAggregate
This operator aggregates the input rows by evaluating the values of the designated grouping columns and applying specified aggregate functions, such as GROUP BY, DISTINCT, SUM, and COUNT, to generate the aggregated results. A large number of resources, such as CPU and memory resources, are required to use this operator.
Join
The NestedLoopJoin operator executes inequality joins. The LookUpJoin operator is optimized from NestedLoopJoin.
Sort
Common Sort operators are MergeSort, MemorySort, and TopN.
DirectPushdownNode
This operator directly pushes SQL statements to DNs for execution.
Project
This operator is used for projection. It selects specific columns from the input data or executes calculation on specific columns using functions or expressions before outputting the results.
Table 2 Description of the EXPLAIN column
Column Name
table
Table that the row of data belongs to
type
Type of the connection. Connection types in descending order of execution speed: const, eq_reg, ref, range, index, and ALL.
possible_keys
Index that may be applied to the table
key
Index that is actually used. If the value is NULL, no index is used. In some cases, MySQL may choose to optimize indexes, for example, force MySQL to use an index by adding USE INDEX(indexname) to a SELECT statement or to ignore an index by adding IGNORE INDEX(indexname).
key_len
Length of the used index. The shorter the length is, the better the index is if accuracy is not affected.
ref
Column where the index is used. The value is generally a constant.
rows
Rows of the data returned by MySQL Currently, only the query result of database 0 is returned. To view all physical distribution of the current table, run the SHOW TOPOLOGY command.
Extra
Additional information about how MySQL parses queries
SQL Restrictions
  • Temporary tables are not supported.
  • Foreign keys, views, cursors, triggers, and stored procedures are not supported.
  • Customized data types and functions are not supported.
  • Process control statements such as IF and WHILE are not supported.
  • Compound statements such as BEGIN...END, LOOP...END LOOP, REPEAT...UNTIL...END REPEAT, and WHILE...DO...END WHILE are not supported.
DDL Syntax
  • Sharded and broadcast tables do not support foreign keys.
  • Modifying sharding keys is not supported.
  • ALTER DATABASE Syntax is not supported.
  • Creating sharded or broadcast tables from another table is not supported.
  • The CREATE TABLE statement does not support GENERATED COLUMN.
  • Modifying sharding keys or global sequence fields using the ALTER command is not supported.
  • Creating TEMPORARY sharded or broadcast tables is not supported.
  • A logical table name contains only letters, digits, and underscores (_).
  • CREATE TABLE ... LIKE statement is not supported.
  • CREATE TABLE ... SELECT statement is not supported.
  • Updating the sharding key by executing INSERT INTO ON DUPLICATE KEY UPDATE is not supported.
  • Cross-schema DDL is not supported, for example, CREATE TABLE db_name.tbl_name (... )
  • Reverse quotation marks are required to quote identifiers such as table names, column names, and index names that are MySQL key words or reserved words.
DML Syntax
  • PARTITION clauses are not supported.
  • Nesting a subquery in an UPDATE statement is not supported.
  • INSERT DELAYED Syntax is not supported.
  • STRAIGHT_JOIN and NATURAL JOIN are not supported.
  • Multiple-table UPDATE is supported if all tables joined across shards have primary keys.
  • Multiple-table DELETE is supported if all tables joined across shards have primary keys.
  • Variables cannot be referenced or operated in SQL statements.
    Example:
    SET @c=1, @d=@c+1;
    SELECT @c, @d;
  • Inserting keyword DEFAULT or updating a sharding key value to DEFAULT is not supported.
  • Repeatedly updating the same field in an UPDATE statement is not supported.
  • Updating a sharding key using UPDATE JOIN syntax is not supported.
  • UPDATE cannot be used to update self-joins.
  • Referencing other object columns in assignment statements or expressions may cause unexpected update results.
    Example:
    update tbl_1 a,tbl_2 b set a.name=concat(b.name,'aaaa'),b.name=concat(a.name,'bbbb') on a.id=b.id;
  • If a text protocol is used, BINARY, VARBINARY, TINYBLOB, BLOB, MEDIUMBLOB, and LONGBLOB data must be converted into hexadecimal data.
  • DDM processes invalid data based on sql_mode settings of associated MySQL instances.
  • UPDATE JOIN supports only joins with WHERE conditions.
  • The expression in a SQL statement has a maximum of 1000 factors.
Unsupported Functions
  • XML functions
  • GTID functions
  • Full-text search functions
  • Enterprise encryption functions
  • Function row_count()
Subqueries
Using subqueries in the HAVING clause and the JOIN ON condition is not supported.
Data Types
Spatial data types are not supported.
Comments
  • Single-line comment
    • A single-line comment can start with a pound sign (#). Any text between # and the end of the line is considered as comment content.
      Example:
      SELECT * FROM customers; # comment content
    • You can also start with two consecutive hyphens (--). There should be at least one space following the second hyphen. Otherwise, the comment may not be correctly parsed.
      Example:
      SELECT * FROM Product; -- comment content
  • Multi-line comment
    /* and */ are start and end delimiters for a comment that contains multi-line texts. It can span over multiple lines.
    Example:
    Comment line
    SELECT DISTINCT product_id, purchase_price FROM Product;
