Updated on 2026-08-04 GMT+08:00
Sharding Algorithm Overview
Supported Sharding Algorithms
DDM supports database sharding, table sharding, and a variety of sharding algorithms.
Table 1 Sharding algorithms
Algorithm
Database Sharding Supported
Table Sharding Supported
MOD_HASH
Performing a simple modulo operation
Yes
Yes
MOD_HASH_CI
Performing a simple modulo operation (case-insensitive)
Yes
Yes
HASH
Calculating the CRC32 value and performing the modulo operation
Yes
Yes
RANGE
Performing a RANGE-based operation
Yes
No
RIGHT_SHIFT
Arithmetically right shifting a sharding key value and then performing a modulo operation
Yes
Yes
YYYYMM
Getting a hash code for a YearMonth object and then performing a modulo operation
Yes
Yes
YYYYDD
Getting a hash code for a YearDay object and then performing a modulo operation
Yes
Yes
YYYYWEEK
Getting a hash code for a YearWeek object and then performing a modulo operation
Yes
Yes
MM
Getting a hash code for a MONTH object and then performing a modulo operation
No
Yes
DD
Getting a hash code for a DAY object and then performing a modulo operation
No
Yes
MMDD
Getting a hash code for a MonthDay object and then performing a modulo operation
No
Yes
WEEK
Getting a hash code for a WEEK object and then performing a modulo operation
No
Yes
  • Database and table sharding keys cannot be left blank.
  • In DDM, sharding of a logical table is defined by the sharding function (number of shards and routing algorithm) and the sharding key (MySQL data type).
  • If a logical table uses different database and table sharding algorithms, DDM will perform full-shard or full-table scanning when you do not specify database and table conditions in SQL queries.
Data Type of Sharding Algorithms
Different sharding algorithms support different data types. The following table lists supported data types.
Table 2 Supported data types
Sharding Algorithm
TINYINT
SMALLINT
MEDIUMINT
INTEGER
INT
BIGINT
CHAR
VARCHAR
DATE
DATETIME
TIMESTAMP
OTHERS
MOD_HASH
MOD_HASH_CI
HASH
RANGE
RIGHT_SHIFT
YYYYMM
YYYYDD
YYYYWEEK
MM
DD
MMDD
WEEK
: Supported. ×: Not supported.
Table Creation Syntax of Sharding Algorithms
DDM is compatible with table creation syntax of MySQL databases and adds keyword partition_options for databases and tables sharding.
CREATE TABLE [IF NOT EXISTS] tbl_name
(create_definition,...)
[table_options]
[partition_options]
 partition_options:
  DBPARTITION BY
       {{RANGE|HASH|MOD_HASH|RIGHT_SHIFT|YYYYMM|YYYYWEEK|YYYYDD}([column])}
      [TBPARTITION BY
{{HASH|MOD_HASH|UNI_HASH|RIGHT_SHIFT|YYYYMM|YYYYWEEK|YYYYDD}(column)}
          [TBPARTITIONS num]
