Help Center/ Distributed Database Middleware/ User Guide/ SQL Syntax/ Global Sequence/ Using NEXTVAL or CURRVAL to Query Global Sequence Numbers
Updated on 2024-07-30 GMT+08:00
- NEXTVAL returns the next sequence number, and CURRVAL returns the current sequence number. nextval(n) returns n unique sequence numbers.
- nextval(n) can be used only in select sequence.nextval(n) and does not support cross-schema operations.
- currval(n) is not supported.
- Connect to a DDM instance.
For details, see Connecting to a DDM Instance.
- Open the required schema.
- Run the following command to create a global sequence:
create sequence seq_test;
- Run the following command to obtain the next sequence number:
select seq_test.nextval;
- Run the following command to obtain the current sequence number:
select seq_test.currval;
- Run the following command to obtain sequence numbers in batches:
select seq_test.nextval(n);
- Cross-schema operations are not supported when sequence numbers are obtained in batches.
- If no global sequence is used, CURRVAL returns 0.
Parent topic: Global Sequence
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
