- What's New
- Getting Started
- User Guide
- What Is DCC?
- How Is a DCC Billed?
- What Steps Will Be Taken by Huawei Cloud to Handle a Server Fault in a DCC?
- How Do I Select a Region?
- How Is the Memory Allocation Rate in a DCC Computing Resource Pool Calculated?
- FAQs About ECSs
- What Are the Characteristics of ECSs in a DeC?
- How Is an ECS in a DeC Billed?
- API Reference
- Glossary
- More Documents
Enabling a DeC
You must enable a DeC before you apply for DCC resources.
Log in to the management console. Click Service List. Under Compute, click Dedicated Cloud. On the DeC page, you can view the process for requesting a DeC and using resources.
Figure 1 DeC requesting and resource application process
- Make a call to the customer service to learn DeC advantages and benefits. To get the phone number, visit at:
- Negotiate with your account manager. The account manager will help you shape a business model based on your service scenarios and requirements and offer the most suitable DeC for you.
- Submit a service ticket to have your DeC provisioned.
- After DeC is provisioned, select desired resource pools and flexibly manage your resources.
