Updated on 2025-09-16 GMT+08:00
Viewing Metrics
  2. On the console homepage, click in the upper left corner and select the desired region and project.
  3. Click to display Service List and choose Management & Governance > Cloud Eye.
    Figure 1 Cloud Eye
  4. In the navigation pane on the left, choose Cloud Service Monitoring. In the displayed list, click Direct Connect DCAAS.
    The Details page is displayed.
  5. Select the resource type from the drop-down list.
    Example:
    • Cloud service: Direct Connect
    • Resource name: Connections
  6. Click the Resources tab.
  7. Locate the target instance and click View Metric in the Operation column.
    You can view data of the last 1, 3, 12, or 24 hours, or last 7 days. You can also specify a time period.
