Monitoring Metrics
Function
This section describes the metrics reported by Direct Connect to Cloud Eye as well as their namespace and dimensions. You can use the management console to query the metrics of the monitored objects and alarms generated for Direct Connect.
You can view metrics of standard connections, full-service connections (dedicated port), and hosted connections.
Namespace
SYS.DCAAS
Connection Monitoring Metrics
| ID | Metric | Description | Value Range | Unit | Conversion Rule | Dimension | Monitoring Interval |
| network_incoming_bits_rate | Network Incoming Bandwidth | Bit rate for inbound data to the Direct Connect side of a connection | ≥ 0 | bit/s | 1000 (SI) | direct_connect_id | 1 minute |
| network_outgoing_bits_rate | Network Outgoing Bandwidth | Bit rate for outbound data from the Direct Connect side of a connection | ≥ 0 | bit/s | 1000 (SI) | direct_connect_id | 1 minute |
| network_incoming_bytes | Network Incoming Traffic | The number of bytes for inbound data to the Direct Connect side of a connection | ≥ 0 | byte | 1000 (SI) | direct_connect_id | 1 minute |
| network_outgoing_bytes | Network Outgoing Traffic | The number of bytes for outbound data from the Direct Connect side of a connection | ≥ 0 | byte | 1000 (SI) | direct_connect_id | 1 minute |
| network_incoming_packets_rate | Network Incoming Packet Rate | Packet rate for inbound data to the Direct Connect side of a connection | ≥ 0 | Packet/s | N/A | direct_connect_id | 1 minute |
| network_outgoing_packets_rate | Network Outgoing Packet Rate | Packet rate for outbound data from the Direct Connect side of a connection | ≥ 0 | Packet/s | N/A | direct_connect_id | 1 minute |
| network_incoming_packets | Network Incoming Packets | The number of packets for inbound data to the Direct Connect side of a connection | ≥ 0 | Packet | N/A | direct_connect_id | 1 minute |
| network_outgoing_packets | Network Outgoing Packets | The number of packets for outbound data from the Direct Connect side of a connection | ≥ 0 | Packet | N/A | direct_connect_id | 1 minute |
| network_status | Port Status | The status of the port used by a connection | 0 indicates DOWN. 1-UP | N/A | N/A | direct_connect_id | 1 minute |
| in_errors | Inbound Error Packets | The number of inbound packets that could not be transmitted to the Direct Connect gateway over the connection because of errors | ≥ 0 | Packet | N/A | direct_connect_id | 1 minute |
| network_incoming_discard_packets_rate | Inbound Packet Discard Rate | The rate at which packets to the cloud over a Direct Connect connection are discarded Packets may be discarded when the transmitted data exceeds the port bandwidth. | ≥ 0 | Packet/s | N/A | direct_connect_id | 1 minute |
| network_outgoing_discard_packets_rate | Outbound Packet Discard Rate | The rate at which packets to the on-premises data center over a Direct Connect connection are discarded Packets may be discarded when the transmitted data exceeds the port bandwidth. | ≥ 0 | Packet/s | N/A | direct_connect_id | 1 minute |
Virtual Interface Monitoring Metrics
| network_incoming_bits_rate | Network Incoming Bandwidth | Bit rate for inbound data to the Direct Connect side of a connection | ≥ 0 | bit/s | 1000 (SI) | virtual_interface_id | 1 minute |
| network_outgoing_bits_rate | Network Outgoing Bandwidth | Bit rate for outbound data from the Direct Connect side of a connection | ≥ 0 | bit/s | 1000 (SI) | virtual_interface_id | 1 minute |
| network_incoming_bytes | Network Incoming Traffic | The number of bytes for inbound data to the Direct Connect side of a connection | ≥ 0 | byte | 1000 (SI) | virtual_interface_id | 1 minute |
| network_outgoing_bytes | Network Outgoing Traffic | The number of bytes for outbound data from the Direct Connect side of a connection | ≥ 0 | byte | 1000 (SI) | virtual_interface_id | 1 minute |
| network_incoming_packets_rate | Network Incoming Packet Rate | Packet rate for inbound data to the Direct Connect side of a connection | ≥ 0 | Packet/s | N/A | virtual_interface_id | 1 minute |
| network_outgoing_packets_rate | Network Outgoing Packet Rate | Packet rate for outbound data from the Direct Connect side of a connection | ≥ 0 | Packet/s | N/A | virtual_interface_id | 1 minute |
| network_incoming_packets | Network Incoming Packets | The number of packets for inbound data to the Direct Connect side of a connection | ≥ 0 | Packet | N/A | virtual_interface_id | 1 minute |
| network_outgoing_packets | Network Outgoing Packets | The number of packets for outbound data from the Direct Connect side of a connection | ≥ 0 | Packet | N/A | virtual_interface_id | 1 minute |
| bgp_receive_route_num_v4 | IPv4 Routes | The number of IPv4 routes that a virtual interface learned through BGP | ≥0 | count | N/A | virtual_interface_id | 1 minute |
| bgp_receive_route_num_v6 | IPv6 Routes | The number of IPv6 routes that a virtual interface learned through BGP | ≥0 | count | N/A | virtual_interface_id | 1 minute |
| bgp_peer_status_v4 | IPv4 Peer Status | Status of an IPv4 virtual interface peer | 0 indicates DOWN. 1 indicates ACTIVE. | N/A | N/A | virtual_interface_id | 1 minute |
| bgp_peer_status_v6 | IPv6 Peer Status | Status of an IPv6 virtual interface peer | 0 indicates DOWN. 1 indicates ACTIVE. | N/A | N/A | virtual_interface_id | 1 minute |
Historical Connection Monitoring Metrics
| network_incoming_bits_rate | Network Incoming Bandwidth | Bit rate for inbound data to the Direct Connect side of a connection | ≥ 0 | bit/s | 1000 (SI) | history_direct_connect_id | 1 minute |
| network_outgoing_bits_rate | Network Outgoing Bandwidth | Bit rate for outbound data from the Direct Connect side of a connection | ≥ 0 | bit/s | 1000 (SI) | history_direct_connect_id | 1 minute |
| network_incoming_bytes | Network Incoming Traffic | The number of bytes for inbound data to the Direct Connect side of a connection | ≥ 0 | byte | 1000 (SI) | history_direct_connect_id | 1 minute |
| network_outgoing_bytes | Network Outgoing Traffic | The number of bytes for outbound data from the Direct Connect side of a connection | ≥ 0 | byte | 1000 (SI) | history_direct_connect_id | 1 minute |
| network_incoming_packets_rate | Network Incoming Packet Rate | Packet rate for inbound data to the Direct Connect side of a connection | ≥ 0 | Packet/s | N/A | history_direct_connect_id | 1 minute |
| network_outgoing_packets_rate | Network Outgoing Packet Rate | Packet rate for outbound data from the Direct Connect side of a connection | ≥ 0 | Packet/s | N/A | history_direct_connect_id | 1 minute |
| network_incoming_packets | Network Incoming Packets | The number of packets for inbound data to the Direct Connect side of a connection | ≥ 0 | Packet | N/A | history_direct_connect_id | 1 minute |
| network_outgoing_packets | Network Outgoing Packets | The number of packets for outbound data from the Direct Connect side of a connection | ≥ 0 | Packet | N/A | history_direct_connect_id | 1 minute |
| network_status | Port Status | The status of the port used by a connection | 0 indicates DOWN. 1-UP | N/A | N/A | history_direct_connect_id | 1 minute |
Dimensions
| Key | Value |
| direct_connect_id | Connection ID. You can query the connection ID on the connection list page. |
| virtual_interface_id | Virtual interface ID. You can query the virtual interface ID on the virtual interface list page. |
| history_direct_connect_id | Historical connection ID. You can query the connection ID on the historical connection list page. |
