- What's New
- Function Overview
- Product Bulletin
- Billing
- Getting Started
- User Guide
Best Practices
- Direct Connect Best Practices
- Connecting an On-Premises Data Center to a VPC over a Single Connection and Using Static Routing to Route Traffic
- Connecting an On-Premises Data Center to a VPC over a Single Connection and Using BGP Routing to Route Traffic
- Connecting an On-Premises Data Center to a VPC over Two Connections in Load Balancing Mode (Virtual Gateway)
- Connecting an On-Premises Data Center to a VPC over Two Connections in an Active/Standby Pair (Virtual Gateway)
- Connecting an On-Premises Data Center to Multiple VPCs that Do Not Need to Communicate with Each Other
- Connecting an On-Premises Data Center to Multiple VPCs in the Same Region Using Direct Connect and VPC Peering
- Using a Public NAT Gateway and Direct Connect to Accelerate Internet Access
- Allowing On-Premises Servers to Access Cloud Services Using Direct Connect and VPC Endpoint
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Connections
- Virtual Gateways
Virtual Interfaces
- Creating a Virtual Interface
- Querying the Virtual Interface List
- Querying Details About a Virtual Interface
- Updating a Virtual Interface
- Deleting a Virtual Interface
- Creating a Virtual Interface Peer
- Updating a Virtual Interface Peer
- Deleting a Virtual Interface Peer
- Performing a Virtual Interface Switchover Test
- Querying the List of Virtual Interface Switchover Test Records
- Tag Management
- Quota Management
- Global DC Gateways
- Peer Links
- Connect Gateways
- Global EIPs
- Global DC Gateway Route Tables
- Public Parameters
- Appendix
- SDK Reference
- Troubleshooting
Popular Questions
- What Are the Network Requirements for Connections?
- What Locations Are Available for Direct Connect?
- How Do I Select a Carrier When Purchasing a Connection?
- How Will I Be Billed for Direct Connect?
- How Do I Submit a Service Ticket?
- How Do I Test the Network Connectivity Between a Location and the Cloud?
- What Do I Do If I Select the Wrong Carrier When Creating a Connection?
Product Consultation
- What Are 1GE and 10GE?
- Is BGP Routing Supported in Direct Connect?
- What Is Full-Service Installation Statement?
- What Are the Network Latency and Packet Loss Rate of a Connection?
- Are the Uplink and Downlink Bandwidths of a Direct Connect Connection the Same?
- How Do I Plan the VPCs for a New Connection?
- What Are Local and Remote Gateways (Interconnection IP Addresses)?
- How Do I Configure BFD for a Connection?
- Leased Line
Interconnection with the Cloud
- Can I Access the Same VPC over Multiple Connections?
- How Do I Plan the CIDR Blocks for a Connection?
- What Should I Consider When I Use Direct Connect to Access the Cloud?
- Does Direct Connect Support NAT?
- Can the VLAN of the On-premises Network Be Used in the VPC Through Direct Connect?
- Can My On-Premises Data Center Access Multiple VPCs Through One Connection?
- Can Direct Connect Be Used with Similar Services of Other Cloud Service Providers?
Networking and Scenarios
- Can Multiple Connections Access the Same VPC?
- Can I Limit the Bandwidth Available on Each Hosted Connection?
Related Console Operations
- How Can I Unsubscribe from Direct Connect?
- What Parameters Can Be Modified After I Have Created a Virtual Interface?
- Do I Need to Delete the Virtual Gateway and Virtual Interface Before Deleting a Hosted Connection?
- How Do I Change the Routing Mode of a Connection?
- How Do I Delete a Hosted Connection?
- What Is the BGP ASN Used by Huawei Cloud?
- Troubleshooting
- Billing
- Resource Monitoring
- Quota
Popular Questions
More Documents
- User Guide (ME-Abu Dhabi Region)
- User Guide (Paris Region)
- eu-west-0-api
- User Guide (Kuala Lumpur Region)
- Before You Start
- API Overview
- Calling APIs
- API Usage
API
- Connection
- Virtual Gateway
Virtual Interface
- Querying the Switchover Test Records of a Virtual Interface
- Tag management
- Quota Management
- Public Parameters
- Appendixes
- Change History
Show all
Overview
Monitoring is critical to ensuring the performance, reliability, and availability of a service. Monitoring data lets you keep track of the status of your resources. Cloud Eye collects and displays monitoring data for you in a convenient, visualized manner. You can use Cloud Eye to automatically monitor connections in real time and manage alarms and notifications, so that you can keep track of the performance of each connection.
To learn more information, see the following topics:
