Operations Connections
Creating an Operations Connection
If you are a partner, you can create an operations connection.
- Go to the Connections page.
- In the upper left corner of the page, click
and select a region and project. - In the upper right corner, click Create Operations Connection.
- Configure the parameters and click Create Now.
- Confirm the order and click Pay.
- Click Pay.
Viewing an Operations Connection
You can view details about an operations connection that you have created.
and select a region and project. - Locate the operations connection you want to view and click its name.
- View details about the operations connection.
Modifying an Operations Connection
You can modify the name, bandwidth, equipment room address, and description of an operations connection.
and select a region and project. - In the operations connection list, locate the operations connection you want to modify and click More > Modify in the Operation column.
- Modify the connection and then click OK.
Unsubscribing from an Operations Connection
You can unsubscribe from an operations connection if you no longer need it.
Delete the virtual gateway and virtual interface associated with your connection, delete the connection, and unsubscribe from the operations connection.
and select a region and project. - In the operations connection list, locate the operations connection that you want to unsubscribe from and choose More > Unsubscribe in the Operation column.
- In the operations connection list, locate the target operations connection and click Unsubscribe from Resource in the Operation column.
- On the displayed Unsubscribe page, confirm the amount to be refunded.
- Click Confirm.
Renewing an Operations Connection
You can renew the subscription if an operations connection is about to expire.
and select a region and project. - In the operations connection list, locate the operations connection you want to renew and choose More > Renew in the Operation column.
- Set the duration that you want to renew the connection and click Pay. Then pay the order as prompted.
