Help Center/ Direct Connect/ User Guide/ Virtual Interfaces/ Creating a Virtual Interface
Updated on 2026-01-26 GMT+08:00
After the connection and the gateway are ready, you need to create a virtual interface so that your on-premises network can access the VPC.
You can create virtual interfaces for the current account or other accounts.
This section describes how to create a virtual interface for the current account and a virtual interface for another account.
  1. Go to the Virtual Interfaces page.
  2. In the upper left corner of the page, click and select a region and project.
  3. In the upper right corner, click Create Virtual Interface.
    Configure the parameters based on Table 1.
    Figure 1 Creating a virtual interface
    Table 1 Parameters for creating a virtual interface
    Example Value
    Virtual Interface Owner
    Specifies the account that this virtual interface will be created for. There are two options:
    • Current account: You will create a virtual interface for the current account.
    • Another account: You will create a virtual interface for another account so that this account can use your connection to access the VPC from the on-premises data center.
    Select Current account in this example.
    Current account
    Region
    Specifies the region where the connection is deployed. You can also change the region here or in the upper left corner of the console.
    CN-Hong Kong
    Name
    Specifies the virtual interface name.
    The name can contain 1 to 64 characters.
    vif-123
    Virtual Interface Priority
    Specifies whether the virtual interface will be preferentially used over other virtual interfaces. There are two options: Preferred and Standard.
    If multiple virtual interfaces are associated with one Direct Connect device, the load is balanced among virtual interfaces with the same priority, while virtual interfaces with different priorities are working in active/standby pairs.
    Preferred
    Connection
    Specifies the connection you will use to connect your on-premises network to Huawei Cloud.
    dc-123
    Gateway
    Specifies the type of the gateway that the virtual interface connects to.
    You can select a virtual gateway or global DC gateway.
    Virtual gateway
    Virtual Gateway
    This parameter is mandatory when Virtual Interface Owner is set to Current account and Gateway is set to Virtual gateway.
    Select a virtual gateway that the virtual interface connects to.
    vgw-123
    Global DC Gateway
    This parameter is mandatory when Virtual Interface Owner is set to Current account and Gateway is set to Global DC gateway.
    Select a global DC gateway that the virtual interface connects to.
    dgw-123
    VLAN
    Specifies the ID of the VLAN for the virtual interface.
    You need to configure the VLAN if you create a standard connection.
    The VLAN for a hosted connection will be allocated by the partner. You do not need to configure the VLAN.
    30
    Enterprise Project
    Specifies the enterprise project by which virtual interfaces are centrally managed. Select an existing enterprise project.
    default
    Bandwidth (Mbit/s)
    Specifies the bandwidth that can be used by the virtual interface. The bandwidth cannot exceed that of the connection.
    50 Mbit/s
    Enable Rate Limiting
    Limits the highest bandwidth that can be used by the virtual interface.
    If this option is enabled, the rate limit gradients are as follows:
    • If the bandwidth is less than or equal to 100 Mbit/s, the rate limit gradient is 10 Mbit/s.
    • If the bandwidth is greater than 100 Mbit/s but is less than or equal to 1,000 Mbit/s, the rate limit gradient is 100 Mbit/s.
    • If the bandwidth is greater than 1,000 Mbit/s but is less than or equal to 100 Gbit/s, the rate limit gradient is 1 Gbit/s.
    • If the bandwidth is greater than 100 Gbit/s, the rate limit gradient is 10 Gbit/s.
    For example, if the bandwidth is 52 Mbit/s, the actual rate limit is 60 Mbit/s. If the bandwidth is 115 Mbit/s, the actual rate limit is 200 Mbit/s.
    We are launching bandwidth rate limiting for virtual interfaces across all regions. Check which regions support this feature on the management console.
    Not enabled
    Tag
    Adds tags to help you identify your virtual interface. You can change them after the virtual interface is created.
    example_key1
    example_value1
    IP Address Family
    Specifies the address type of the virtual interface.
    The default option is IPv4.
    IPv4
    Local Gateway
    Specifies the IP address used by Huawei Cloud to connect to your on-premises network. After you configure Local Gateway on the console, the configuration will be automatically delivered to the gateway used by Huawei Cloud.
    10.0.0.1/30
    Remote Gateway
    Specifies the IP address used by the on-premises data center to connect to Huawei Cloud. After you configure Remote Gateway on the console, you need to configure the IP address on the interface of the on-premises device.
    CAUTION:
    The IP addresses of the local gateway and remote gateway must be in the same IP address range. Generally, an IP address range with a 30-bit mask is used. The IP addresses you plan cannot conflict with IP addresses used on your on-premises network. Plan an IP address range that will be used at both ends of the connection for network communications between your on-premises data center and the cloud.
    10.0.0.2/30
    Routing Mode
    Specifies whether static routing or BGP routing is used to route traffic between your on-premises network and the cloud network.
    If there are or will be two or more connections, select BGP routing for higher availability.
    BGP
    Remote Subnet
    Specifies the subnets and masks of your on-premises network. If there are multiple subnets, use commas (,) to separate them.
    This parameter is required when static routing is selected.
    192.168.51.0/24, 10.1.123.0/24
    BGP ASN
    Specifies the autonomous system (AS) number of the BGP peer.
    This parameter is required when BGP routing is selected.
    12345
    BGP MD5 Authentication Key
    Specifies the password used to authenticate the BGP peer using MD5.
    This parameter can be set when BGP routing is selected, and the parameter values on both gateways must be the same.
    The key contains 8 to 255 characters and must contain at least two types of the following characters:
    • Uppercase letters
    • Lowercase letters
    • Digits
    • Special characters ~!,.:;-_"(){}[]/@#$%^&*+\|=
    Qaz12345678
    Provides supplementary information about the virtual interface.
    When you configure the local and remote gateways, note the following:
    • The local gateway is used by Huawei Cloud for connecting to your equipment room. After you configure Local Gateway on the console, the configuration will be automatically delivered to the gateway used by Huawei Cloud.
    • The remote gateway is used by your equipment room for connecting to Huawei Cloud. After you configure Remote Gateway on the console, you also need to configure the gateway deployed in your equipment room.
    • The local and remote gateways must use the same CIDR block and cannot conflict with service IP addresses on the network.
  4. Click Create Now. When the status of the virtual interface changes to Normal, the virtual interface has been created.
    Ping the IP address of a server in the VPC from your on-premises data center to test network connectivity. If the test is successful, your on-premises data center can connect to Huawei Cloud and access the desired VPC.
You can create a virtual interface for another account so that this account can use your connection to access the VPC.
Virtual interfaces that you create for other users take effect only after the users accept them.
  4. Configure the parameters based on Table 2.
    Table 2 Parameters for creating a virtual interface for another account
    Example Value
    Specifies the account that this virtual interface will be created for. You create a virtual interface for another account so that this account can use your connection to access the VPC.
    Another account
    Region
    Specifies the region where the connection is deployed. You can also change the region in the upper left corner of the console.
    CN-Hong Kong
    Name
    vif-123
    Preferred
    Connection
    Specifies the connection you can use to connect your on-premises network to Huawei Cloud.
    dc-123
    Gateway
    In this example, select a virtual gateway.
    Virtual gateway
    Project ID
    Specifies the ID of the project that the virtual gateway belongs to. This parameter is mandatory when Gateway is set to Virtual gateway.
    On the management console, hover the cursor on the account name in the upper right corner and select My Credentials. On the My Credentials page, view the project ID.
    ID
    Specifies the ID of the virtual gateway. This parameter is mandatory when Gateway is set to Virtual gateway.
    In the virtual gateway list, hover the cursor on the virtual gateway name and view the name and ID of the virtual gateway.
    Project ID
    Specifies the ID of the project that the global DC gateway belongs to. This parameter is mandatory when Gateway is set to Global DC gateway.
    Global DC Gateway ID
    Specifies the ID of the global DC gateway. This parameter is mandatory when Gateway is set to Global DC gateway.
    In the global DC gateway list, hover the cursor over the global DC gateway name and view the name and ID of the global DC gateway.
    VLAN
    30
    Bandwidth (Mbit/s)
    50 Mbit/s
    Limits the highest bandwidth that can be used by the virtual interface. If this option is enabled, the rate limit gradients are as follows:
    Bandwidth rate limiting of virtual interfaces is being and will be launched in each region. You can view the regions where bandwidth rate limiting is rolled out on the management console.
    Not enabled
    Tag
    example_key1
    example_value1
    IP Address Family
    IPv4 is selected by default.
    IPv4
    Local Gateway
    10.0.0.1/30
    Remote Gateway
    CAUTION:
    10.0.0.2/30
    Routing Mode
    Remote Subnet
    BGP
    BGP ASN
    Specifies the ASN of the BGP peer.
    12345
    • Uppercase letters
    • Lowercase letters
    • Digits
    Qaz12345678
  5. Click Create Now. When the status of the virtual interface changes to Normal, the virtual interface has been created.
