Updated on 2026-01-09 GMT+08:00
Creating a Virtual Gateway
You can create a virtual gateway and associate it with the VPC that you need to access.
  1. Go to the Virtual Gateways page.
  2. In the upper left corner of the page, click and select a region and project.
  3. In the upper right corner, click Create Virtual Gateway.
  4. In the Create Virtual Gateway dialog box, set the parameters based on Table 1.
    Figure 1 Creating a virtual gateway
    Table 1 Parameters required for creating a virtual gateway
    Example Value
    Name
    Specifies the virtual gateway name.
    The name can contain 1 to 64 characters.
    vgw-123
    Enterprise Project
    Specifies the enterprise project by which virtual gateways are centrally managed. Select an existing enterprise project.
    default
    VPC
    Specifies the VPC to be associated with the virtual gateway.
    VPC-001
    Local Subnet
    Specifies the CIDR blocks of the subnets in the VPC to be accessed using Direct Connect.
    You can add one or more CIDR blocks. If there are multiple CIDR blocks, separate them with a comma (,).
    192.168.0.0/16
    BGP ASN
    Specifies the BGP ASN of the virtual gateway.
    Generally, Huawei Cloud's BGP ASN is 64512. There are two special cases:
    • In the CN North-Beijing1 region, the default BGP ASN of Huawei Cloud is 65533.
    • In the AP-Bangkok region, the BGP ASN of some Direct Connect locations is 65535 by default. For details, contact the Direct Connect manager.
    64512
    Tag
    Adds tags to help you identify your virtual gateway. You can change them after the virtual gateway is created.
    example_key1
    example_value1
    Provides supplementary information about the virtual gateway.
  5. Click OK.
    When the status changes to Normal, the virtual gateway has been created.
