Updated on 2026-01-06 GMT+08:00
Managing Virtual Gateways
You can view, modify, and delete a virtual gateway.
Viewing a Virtual Gateway
  1. Go to the Virtual Gateways page.
  2. In the upper left corner of the page, click and select a region and project.
  3. Locate the virtual gateway and click its name to view the details.
    Figure 1 Viewing a virtual gateway
Modifying a Virtual Gateway
  3. Locate the virtual gateway you want to modify and click Modify in the Operation column.
  4. Modify the parameters as needed and click OK.
    Figure 2 Modifying a virtual gateway
Deleting a Virtual Gateway
  3. Locate the virtual gateway you want to delete and click Delete in the Operation column.
  4. In the displayed dialog box, click OK.
    Figure 3 Deleting a virtual gateway
